Modular V10 (6.8l)
Need help
Old Mar 3, 2012 | 04:32 PM
topscrt's Avatar
topscrt
Need help
I changed my plugs and I must of put too much anti-seize and not it acts like it's misfiring. Went to dealership to look at and they want to charge me 200 to clean it.
Can I just you carb cleaner on the plugs and down the spark plug hole to clean thread or will it hurt something
Old Mar 3, 2012 | 04:55 PM
rob.hvac's Avatar
rob.hvac
Yes you can are you getting any codes to know what cylinders are missing so you dont have to do it to all of them
Old Mar 3, 2012 | 05:01 PM
topscrt's Avatar
topscrt
no codes. Just wonders if I spray carb cleaner down the holes will it do any damage
Old Mar 3, 2012 | 06:43 PM
dkf's Avatar
dkf
I would pull each plug and clean everything off the plugs and reinstall them. Reinstalling the clean plug should push some of the antiseize out. Anti-seize usually has a very high content of conductive solids in it so I can't imagine it causing too much issues for you.
You could always use an O2 safe carb cleaner but don't use much as you don't want to hydrolock the piston. Keep in mind the carb cleaner will just flush the junk into the cylinder. Its possible you could also have a new bad plug, not common but it happens. Your not using Bosch plugs are you?
Old Mar 3, 2012 | 11:53 PM
topscrt's Avatar
topscrt
no bosch. Autolite
Old Mar 5, 2012 | 10:28 AM
Big Orn's Avatar
Big Orn
In the past I have bought 4 new coils that have been bad. All 4 have been bought from a Ford dealership. Went to a parts house and got the $36 coils and so far no problems. You need to make sure what the problem is before doing anything. JMHO on that.
woopud
2004 - 2008 F150
Apr 8, 2019 09:31 AM
5.43v
2004 - 2008 F150
Aug 13, 2018 08:50 PM
Dullah
2004 - 2008 F150
May 12, 2017 06:48 PM
quakerj
Nov 17, 2013 10:25 AM
gtex
Jan 12, 2006 07:37 PM
