Spark plugs
Old Apr 6, 2019 | 05:45 PM
woopud's Avatar
woopud
Spark plugs
So, I just replaced the spark plugs on my '05 5.4. at 190,000 miles, last time I replaced them was at 119,000 miles. The first time I broke 6 out of 8, this time none! What was weird though is that all 4 on the passenger side came out easy while all 4 on the drivers side were thight as hell. What could be causing that?
Old Apr 7, 2019 | 08:27 AM
redfishtd's Avatar
redfishtd
Carbon build up around tip of plug
It is highly advised to remove carbon that breaks plugs going in and out . It also changes heat range of plug . Using carb cleaner and a brush or swab, Carb cleaner will disolve carbon. Just be careful to not drop anything in cly . Orig ford tsb on plugs was to soak plug with carb cleaner then turn back and forth to work it past threads . Then they had you coat the snout with nickel antiseize to stop carbon from seizeing it in the future.
Old Apr 7, 2019 | 08:35 AM
woopud's Avatar
woopud
The other thing is that I couldn't even get the socket on the plugs, there was a lot of dirt build up around the plugs. I followed the advise of someone on this forum and used a holesaw with a extension to break up the dirt and then blow it out with a compressor.
Old Apr 8, 2019 | 09:31 AM
redfishtd's Avatar
redfishtd
Yes the hole saw trick is viable . Changing plugs and boots every 60k is the new ford standard . Blowing air out all around before pulling cops stops some stuff form getting past boots . Then blow out each hole as you pull plugs as you don't want this stuff in cyl ,sand etc .Anti- freeze , oil ,heat destroys boots .Leave all holes covered when open ,I use rags .Its like pin ball something will find that hole .Pulling valve covers is another place to blow air to keep dirt out of oily valve train .
Using carb cleaner in hole helps remove anti freeze ,oil,carbon in tip area etc . Keep your hands clean handling plugs boots as you can contaminate high volt surfaces . If you drop a plug on cement it is not wise to use it . Use rubber socket and be gentle with plugs .
Bobbys Big Red Rig
2004 - 2008 F150
19
Sep 5, 2017 08:09 PM
Dullah
2004 - 2008 F150
May 12, 2017 06:48 PM
67f100
Aug 18, 2009 05:03 PM
8ITCOOL
Jul 2, 2004 07:54 AM
Frank Lang
May 19, 2004 11:03 PM
