AS 21820 3/01/2011
"FORD: THERE MAY BE FUEL CONTAMINATION CAUSING DAMAGE TO THE FUEL SYSTEM. THE VEHICLE MAY NOT START, HAVE A HARD START, RUN ROUGH, HAVE EXHAUST SMOKE, OR THE ENGINE MAY KNOCK. 2011 F SUPER DUTY. *RM"
2011 Ford F-450 Sd Fuel System, Diesel Service Bulletin 321009
NHTSA: Action Number: 10039054 Service Bulletin Number: 321009
Report Date:
Mar 01, 2011Component:
Fuel System, Diesel
Summary: Ford: there may be fuel contamination causing damage to the fuel system. The vehicle may not start, have a hard start, run rough, have exhaust smoke, or the engine may knock. 2011 f super duty. *rm
Went back to AutoMD site and tried to find TSB's on Super Duty's and found none.... hmmmmmm.....
Reason: Add info
This information was found from the "Recalls/TSB" tab at the top of this page.
I have seen it referenced other places as well. Ford Technical Service Bulletins - Page 113 | AutoMD
This info is brand new Mar 01, 2011.
TSB data for: 2011 FORD F-350 SD
Bulletin Number: AS-21820
Sequence Number: 10039054
Date: 20110301
Component Name: 061200 ENGINE AND ENGINE COOLING:ENGINEIESEL
Make: FORD
Model: F-350 SD
Year: 2011
Summary:
<TABLE>OASIS SPECIAL SERVICE MESSAGE NUMBER: 21820 MESSAGE TITLE: 2011 F-SUPER DUTY EQUIPPED WITH 6.7L DIESEL ENGINE - POOR QUALITY DIESEL, GASOLINE OR OTHER NON-DIESEL FUELS ADDED TO THE FUEL TANK - SERVICE TIP APPLICABLE VEHICLES : 2011 TRUCK : 00028 F-SERIES OASIS MESSAGE :
2011 F-SUPER DUTY VEHICLES EQUIPPED WITH A 6.7L DIESEL ENGINE WHICH HAVE
EXPERIENCED FUEL SYSTEM CONTAMINATION MAY HAVE DAMAGED FUEL SYSTEM COMPONENTS
INCLUDING THE HIGH PRESSURE (HP) PUMP AND FUEL INJECTORS. FUEL AND ADDITIVES
WHICH DO NOT MEET THE MINIMUM LUBRICATION, COOLING AND ANTI-CORROSION PROPERTIES
REQUIRED BY THE HIGH PRESSURE FUEL SYSTEM COMPONENTS MAY CAUSE SYMPTOMS
INCLUDING, BUT NOT LIMITED TO, THE FOLLOWING: CRANK/NO START, LONG CRANK/HARD
START, ROUGH RUN, LOW POWER, ENGINE KNOCKING, EXHAUST SMOKE AND/OR FUEL RAIL
PRESSURE (FRP) SLOW TO BUILD. TO HELP WITH THE DIAGNOSIS AND REPAIR OF CONCERNS
DUE TO FUEL CONTAMINATION, A JOB AID HAS BEEN DEVELOPED AND IS NOW AVAILABLE ON
THE PTS WEBSITE UNDER THE SERVICE TIPS TAB.
<TBODY></TBODY></TABLE>
If a failure doesn't have an example in this document, is it covered or can dealerships still deny warranty regardless of this document if the truck is stock?
That's just my interpretation of it, I don't work for Ford. Someone else may be able to give a better answer.
