2005 f250 bad engine should I buy?
If you can afford to drop a new engine in it for $4,500 to $7,000 depending on options then that's a fantastic deal. No reason a new engine like that wouldn't give you another 250,000+ miles.
Why don't I find deals like this
Rebuilt Diesel Engines Price List
03-07 6.0L BLACK MAMBA POWERSTROKE CRATE MOTOR 425HP products, buy 03-07 6.0L BLACK MAMBA POWERSTROKE CRATE MOTOR 425HP products from alibaba.com
Reman Rebuilt Dodge Cummins, Ford Powerstroke, GM Duramax Engines For Sale; 5.9, 6.0, 6.2, 6.4, 6.5, 6.6, 7.3 L; Used, Hard-to-Find, Drop-In
Ford 6.0L VT365 Power Stroke Engine Rebuild - Diesel Power Magazine
Here's another option for a source. I haven't done business with them. It's been on my local Craig's list for several months now. Heading says $3,995. Not sure about the "revised" V/R Black Onyx head gasket either.
J&K Engines
11513 Lebanon Rd
Mount Juliet TN 37122
615-758-7749 Office
615-758-7739 Fax
________________________________________________
6.0 Ford Powerstroke Diesel Engine Reman*
Warranty is 1 year with unlimited mileage.
Complete Assembly:
• All internal moving parts are replaced with new parts as needed.
• All oil galleys and passages are blasted out and brushed clean, and then all new freeze plugs and cam bearings are installed.
• Crankshaft is measured and polished, then new rod bearings and main bearings installed, the cam is measured and polished as well.
• New BLACK ONYX revised head gaskets are installed.
• All the factory torque to yield cylinder head bolts are replaced with ARP head studs (a 500.00 value) and then properly torqued.
• Long block is assembled and powder-coated and new rocker arms, roller lifters, and push rods are installed
Complete Disassembly:
• Full cleaning process, block is baked at 650 degrees for 11 hrs, then jet washed and powder coated.
• Cylinder heads are jet washed and powder coated
• Cylinder heads are resurfaced (milled) opn a CNC machine.
• Both cylinder heads and block get pressure checked, then magne-fluxed to check for any imperfections.
• Complete valve job.
• Block is measured, if out of spec we then bore to .020 and install new pistons and rings.
• After bored the block is power honed to match rings.
J&K Engines
11513 Lebanon Rd
615-758-7749 Office
615-758-7739 Fax
Complete Assembly:
Here is the ones I have been using. Just put one in for a customer the other day. Good built motors
Blackwater Engines - Remanufactured Ford, International, Navistar, - 6.0L PowerStroke Diesel
$550?!?!?
For that kind of money it would already be in my garage with me tearing the engine out.
You can sometimes score a good engine out of a wrecked truck on craigslist. Just make sure the year of the motor matches the truck so you don't have to mod the harness for the new motor.
With such a GOLDEN opportunity, I'd bulletproof the motor since you'll already have it out to replace the other one.
-ARP Studs
-EGR Delete
-New Oil Cooler (as a precaution)
-Check and Clean the motor from top to bottom
-Replace all the gaskets and seals from top to bottom (bedplate, rear main, any other potential leak points)
One of these days I'll get my truck a built 6.0 playmate....
But dude, in the meantime, doooooooo iiiiiiitttttt!
-ARP Studs
-EGR Delete
