F6-Tranny and Diff numbers and degreasing
Old Mar 2, 2012 | 04:23 PM
fordtreexr's Avatar
fordtreexr
I was able to clean some of the truck and camwe across these numbers on; the tranny-a big N-9 and also 59T-7006 and for the rear diff what looks like a date 9-48 (when made?) also by this is 19750 (production number??) then towards the bottom of the diff drivers side towards cab is 2015108 (what appearsto be an arrow pointing towardsmore #'s below) 2147145. Can they be parts #'s??Also found model i d plate that says model is WBTH. Any insight???
Old Mar 2, 2012 | 04:25 PM
fordtreexr's Avatar
fordtreexr
oops.. also looking at degreasing. any safe products??
Old Mar 2, 2012 | 11:53 PM
jmadsen's Avatar
jmadsen
Thats a non synchro 4 speed trans (59T). oven cleaner (dollar store) = cheap. and hot pressurized water along with a flathead screwdriver and metal putty knifes help to clean them up.
I borrowed a pressure washer and ran it to the hot water outlet in the house when cleaning up my 52 F6
Old Mar 3, 2012 | 08:28 AM
fordtreexr's Avatar
fordtreexr
thanks for that tranny i.d. I do have the factory shop manual but none of the #s from the parts match what I saw on the truck. Fluids questions too..I'm going to change fluids but the owners manual hasn't come in the mail yet. Diff takes gear lube 90W / tranny uses??? I put 30W non detergent oil in. Wasn't sure though because the shop manual says the heavy trucks used an oil with detergents in them, would a detergent oil at this point clean too much? I've been cleaning with a putty knife wire brush and screw driver. Never thought of oven cleaner. I didn't want to screw up any wires and such. Thank you.
6litrefan
Sep 28, 2009 04:29 PM
84farmtruck
Apr 2, 2009 07:31 PM
02sd
Dec 15, 2005 11:06 AM
cdherman
Oct 8, 2003 08:33 PM
bubbernator
1983 - 2012 Ranger & B-Series
Sep 10, 2002 09:28 AM
