Modded B codes
Old Mar 2, 2012 | 11:31 AM
EX40's Avatar
EX40
Modded B codes
For those of you who've had custom u bolts & center bolt done do you recall the exact lenghts you had the shop make?
Old Mar 2, 2012 | 12:52 PM
robert_l_ross's Avatar
robert_l_ross
I had mine done 1.5" longer than stock, then cut down the excess. I would advise 1.5" to 2" so you can use the bolt to align the leaves instead of having to go out and get a driff pin. Then just use a cutting wheel and cut off any excess after you get the nut tightened down.
magnumak1
May 4, 2014 06:10 PM
Treytaw
Apr 19, 2013 06:23 AM
Snobord28
Oct 13, 2010 12:54 AM
High_HP
Dec 10, 2007 06:19 AM
69ford99
1978 - 1996 Big Bronco
Nov 13, 2006 05:07 PM
