IH 1086 TURBO
I've rebuilt a couple turbos. It's not hard at all. If you want an upgrade, shop for a Holset HX40 from a Cummins 8.3 of around the same hp level you're at. That, or one off a newer DT466. The newer Garrett is a GT37 or GT40(depending on what you get). The factory IH one is an AiResearch T04(puny little thing).
Thanks for the info, but apparently someone ordered a stock replacement already. But now Im thinking about rebuilding the old one and putting it on our 766 with the 360IH motor. If the wheels havent made contact with the housing the assembly shouldnt need balancing right? Sometimes I've seen endshaft nuts with machine marks so I'm wondering...
Shawn MacAnanny
02-08-2017 05:36 PM
LaJ10
21
08-17-2009 04:35 PM
Ford4x4-JD70AB
Supercharger, Turbocharger, Nitrous Oxide & Water/Methanol Injection
15
09-07-2006 07:29 AM
