429 or 460?
Old Mar 1, 2012 | 05:58 PM
HARDMANHARDMAN's Avatar
HARDMANHARDMAN
429 or 460?
How can I tell the difference between a 429 and a 460? The casting numbers on the heads is C9VE-A and the casting numbers on the block behind the starter is D1VE-A2B. Can I positively ID what size of motor this is by these numbers or do I have to open the motor and measure the rods?
Old Mar 1, 2012 | 09:11 PM
sled250's Avatar
sled250
Drop the oil pan, and get the numbers from the crank to be positive. I got a 429 in mine, and it runs great!!
Old Mar 1, 2012 | 09:17 PM
justforkicks's Avatar
justforkicks
Measure the stroke. 429 should have a 3.59 inch stroke, 460 should have a 3.85 inch stroke. Take out a plug, turn the motor over by hand and stick a piece of wire down the plug hole. At the bottom of the stroke, mark the wire, and same at the top.
Old Mar 1, 2012 | 10:46 PM
Thunderjet4x4's Avatar
Thunderjet4x4
Yep, good info! Use copper wire, or wood dowling, be patient and measure. Basically anything that won't scratch or leave harmful deposits. Beats pullin the oil pan, and searching for numbers.
monster67
Dec 4, 2012 11:53 AM
drumfield
Feb 3, 2011 11:26 PM
bertha66
Apr 26, 2010 01:31 PM
rsalter66
Dec 18, 2007 06:49 AM
THalina
Sep 28, 2004 07:54 PM
