How To: Change CPS + My CPS Blurb
Given how common CPS failures are, I felt a video was necessary. But, its pretty easy, so the last 1/2 of the video is me talking about the CPS and its basic functions.
CPS - YouTube
In the video I talk about the CPS detecting the teeth on a gear. This is the gear in question. Notice the square holes in the gear? This is actually what the CPS is detecting, no the teeth. You will also notice that 2 of the squares are different sizes. These identify cylinder 1 and 4 to the CPS
Thank you to mueckster for the manual citation, and SnackDoc for the picture.
CPS - YouTube
Originally Posted by Ford Manual
The PCM receives engine rotational position information from the Camshaft Position (CMP) sensor. The CMP is a hall-effect device. It outputs 12 volts to the PCM whenever it detects the iron of a spoked target wheel in front of it, and it outputs 0 volts whenever it detects the space between the spokes. The target wheel spokes and spaces are each 15 crank degrees, except for narrow spoke which indicates cylinder No. 1 and a wide spoke which indicates cylinder No. 4 (fires 5th). The NGS PID RPM is generated by the PCM from the CMP signal.
After installing a smoother idle was immediately noticed, and in the weeks following, MPG has improved.
Thank you
Hey thanks for the info...my truck has been chugging and crapping out for a couple months. I was figuring it was something in my fuel or some crap like that the way it acted. Finally put the scanner on it and that's what I came up with. It sure acted strange though, it would chug more on hills and rough roads and some times it would run great for weeks with out messing up once.
Bergerson
22
03-05-2009 11:34 AM
