Help Diagnose This Problem...
Old Mar 1, 2012 | 01:19 PM
F-250 Super Duty's Avatar
F-250 Super Duty
This start on Saturday night on my way home from the N.E.S.T. get together. I pulled into a rest area to re-attach an intercooler pipe that popped out of the boot. When I went to start the truck up this is exactly what it was doing. It has been doing it ever since. It is like this when the truck is up to operating tempature. When it is cold it starts better.
This past July the ICP Sensor was replaced along with the LPOP.
Today I replaced the orings on the IPR and filled the HPOP with fresh oil.
What I'm seeing with AE:
ICP during cranking 2100 psi
ICP Duty Cycle up to 44%
Fuel pressure is steady at 68 PSI
What am I missing?
Click the picture it should take you to the video...
Old Mar 1, 2012 | 01:29 PM
indyF-350psd's Avatar
indyF-350psd
you can't fix stupid!
when i start mine my icp psi spikes to 3000+ psi.....that duty cycle looks a bit high and the pressure looks low to me....are you on stock split shots? might be time for an hpop.....
just re-read your post.....when its cold its better throws an oil related flag up for me.....since oil is thicker when its cold the hpop wont have to work as hard to build pressure but with it warmed up and thinned out a little it sounds like its having a rough time keeping up with the demand needed on startup......jmo.....
Old Mar 1, 2012 | 02:20 PM
F-250 Super Duty
Yes still on stock injectors. Yeah figured it was leaning that way. Is there anyway to 100% rule out ICP or IPR sensors before I drop $450 on a new HPOP?
I don't want to spend $120 for and ICP sensor then $205 for and IPR then have to by the pump in the end. Like I said, I have AE but need to know what to look for to diagnose it....
Old Mar 1, 2012 | 02:24 PM
timmyboy76's Avatar
timmyboy76
you check the easy thing first Mike...oil level?
Old Mar 1, 2012 | 03:41 PM
diesel-fitter-bum01's Avatar
diesel-fitter-bum01
My spare hpop is out on loan,but when I get it back you can use it for a core to get your new one. If this is the case.
Old Mar 1, 2012 | 03:48 PM
F-250 Super Duty
Yes fresh oil change on Friday.
Thanks one the offer for you pump. I hope to have this taken care soon but I'll let you know!
Old Mar 1, 2012 | 03:57 PM
diesel-fitter-bum01
Ok,dean88 has it now. If you need it I will have him send it directly to you.
Old Mar 2, 2012 | 05:25 PM
F-250 Super Duty
Just an update, icp sensor can be ruled out. Air in fuel lines can be ruled out. The problem is constant now. Any time the truck is off for more than one minute the symptoms can be duplicated.
Thinking its still oil related so may go the IPR replacement and possibly a T500. Not sure, really want to spend the cash to finish my vegi conversion.....
Old Mar 2, 2012 | 06:43 PM
rednekrebel28's Avatar
rednekrebel28
The way it seems it looks to be oil related. IPR is one possibilty. My question is if the lpop is on its way out. Was it replaced with a melling? Once oil is warm it becomes thinner. Making in harder to pick up and compress. So if the lpop has some wear or is problematic it could be having a hard time to pick up the oil and move it to the hpop.
I know the lpop was replaced but sometimes that doesnt mean anything...no offense
Old Mar 2, 2012 | 08:12 PM
F-250 Super Duty
LPOP is a Melling and less than a year old.
Old Mar 4, 2012 | 09:02 AM
the1mg's Avatar
the1mg
Can someone tell me what the IPR is? It's not in the list of acronyms
Old Mar 4, 2012 | 09:51 AM
cps's Avatar
cps
Injection pressure regulator.
elderivers
33
May 24, 2016 05:19 PM
sportsdad
13
Jun 8, 2014 05:06 AM
billcollector
Feb 13, 2010 08:35 AM
Mongos4BTswap
28
May 17, 2009 10:09 PM
00SvtLightning
Aug 18, 2008 10:13 AM
