Sponsored by: Real Truck
LED dome light sizes
Old Mar 1, 2012 | 12:53 PM
xmontex4's Avatar
xmontex4
What are the dome light festoon bulb sizes in a 99-07 truck? I have searched and found 2 sizes and I wasn't sure which one had either 2 of the same and 1 of the other or if all 3 are the same. I have been looking inti installing new leds.
Old Mar 1, 2012 | 03:41 PM
TXtinct's Avatar
TXtinct
You'll shoot your eye out
They should be 39mm. Just pull one out of your console and measure it. Probably 1.55ish".
The cheaper route: I have these in my Excursion, very bright... You get 6 festoons for under $14
http://www.ebay.com/itm/320764311412...witem=&vxp=mtr
I also have a few of these in the Excursion, even brighter but more expensive: Each bulb is almost $4
http://www.ebay.com/itm/350518577131...witem=&vxp=mtr
Either way you will be happy switching them out.
Old Mar 1, 2012 | 03:51 PM
xmontex4's Avatar
xmontex4
OK, are all 3 the same?
Old Mar 1, 2012 | 04:06 PM
TXtinct's Avatar
TXtinct
The festoons are the 39mm they should all be the same in your truck, you may want to double check first. The last link I gave you will have the festoon adapter in included with the light, like I said you will only get one bulb for around $4 though. Those are the only two types I would recomend. Pick whichever you want, they will both work, at least they did in my truck.
Old Mar 1, 2012 | 11:54 PM
xmontex4's Avatar
xmontex4
Oh awesome thanks! The links didn't show up earlier on my phone, I've only got 1 dome light so ill probably go with the brighter ones.
Old Mar 2, 2012 | 06:20 AM
TXtinct's Avatar
TXtinct
Cool, just check the number of bulbs in your light and order that number of new ones. Probably 3 but yours may be a little different. Post up some pics before and after.
Old Mar 2, 2012 | 06:56 AM
xmontex4's Avatar
xmontex4
will do thanks! is there any way to just get 2 of those festoon bulbs?
Old Mar 2, 2012 | 07:31 AM
TXtinct's Avatar
TXtinct
Here you go, this is for one. You will have to enter the quantity that you want (2) in the little box. They are coming from Hong Kong so it does take a week or so to get them in.
39mm Festoon WHITE LED DOME TUNK LIGHT Bulb 2W JDM 2*1W | eBay
If you prefer to buy American these are in Cali but I'm pretty sure they all come from the same place... 3 times as much as the first link though.
http://www.ebay.com/itm/2X-39MM-SMD-...item43adace9fc
Old Mar 2, 2012 | 07:41 AM
xmontex4's Avatar
xmontex4
OK, I'd rather pay less and wait for them lol thanks again ill order them and post some pics when I get them installed.
Old Mar 2, 2012 | 08:09 AM
TXtinct's Avatar
TXtinct
Agreed... Let me know if you have any other questions. I've been swapping in led's for years on all my vehicles. I've switched out the glove box, license plate, running boards and reverse lights on my Excursion. There are a ton of lights on these things.
Old Mar 2, 2012 | 08:28 AM
xmontex4's Avatar
xmontex4
Will do! I'm in the process of doing all that as well, I was going to try and change my interior lights to blue but I found out itssomewhat complicated to get the gauge needles back on so now I'm skeptical about it.
Old Mar 2, 2012 | 08:31 AM
TXtinct's Avatar
TXtinct
Where did you get your 08 center console? I can't find one anywhere. Also how did the 08 door panels turn out? Do you have a thread on that?
Old Mar 2, 2012 | 08:48 AM
xmontex4's Avatar
xmontex4
I found d it on eBay a few months ago for 200 it came out of a new tow truck it was a steal because they are usually more expensive lol it was one of the best things I've ever gotten it is so much bigger than the jump sear I never used lol. I have not put the panels in yet I put it in my signature but I'm hopefully going to do it soon and ill take plenty of pictures lol. I still need the driver side switches and the tweeter mounts and then ill be good to go.
Old Mar 20, 2012 | 10:02 PM
xmontex4's Avatar
xmontex4
Finally got my lights it i was so excited i forgot to take before pictures but i will take some after pics and post them up!
Old Mar 21, 2012 | 01:24 AM
A/Ox4's Avatar
A/Ox4
9 ECHO 1
Check out this mod I did the other day.. The bulb is a 578.
Ford Superduty - Red LED Map Light Mod - YouTube
