Barn find update
Old Feb 29, 2012 | 08:31 PM
jak2636's Avatar
jak2636
Barn find update
Since my last post things are moving along. I found a 1979 F150 donor truck for $400. I removed all useful pieces of the donor truck.
> engine 302 V8 and automatic transmission
> front suspension, disk brakes, master cylinder, booster. proportioning valve
> power steering box and hoses as well as all associated linkage, Steering column etc.
> Motor mounts, perches radiator
> complete rear, parking brake cables
I am still looking for a suitable bed floor since my truck does not have one, as well as door hinges and upper rails for the front end.
I tore the engine down and sent it to a local machine shop for the works and the transmission also went to a local shop also to be rebuilt
As you can see the machine shop and transmission shop did a quick turnaround. I assembled the engine, attached the transmission and test fit the assembly in the 1966 chassis. I am currently rebuilding the front end pieces and will try to have the chassis complete by the end of the weekend ----- excluding new brake lines ------- I have not ordered them yet.
If any one is interested I will post hours worked as well as the actual budget for this project as I progress. To-date I spent $795. on the transmission, $2808. for machine shop services and internal engine parts and another $351. On the engine bolt on Items.
I have also purchased add on air conditioning kit and will post its cost when I have everything.
When the chassis is complete I will reinstall the engine and test start it.
If you let me know what areas are of interest you may have, I will try to post pictures and an explanation of what I am doing. My target completion date is June 1 of this year. That is to include me doing all of the body work, patch panels etc, and having a local shop paint the truck .
If you would like to know what I started with I posted an album of the truck as I found it down on the farm.
john
Old Mar 1, 2012 | 02:11 AM
Rgd9664's Avatar
Rgd9664
I saw some 66 f100 door hinges on ebay not long ago. Some guy is just ripping apart these old trucks and parting them out (I mean everything) I got 2 speaker grills and a oem speaker with all the nuts and fittings for a good deal.
Old Mar 1, 2012 | 05:50 AM
jak2636's Avatar
jak2636
Thanks for the tip, I will search the web today.
Old Mar 1, 2012 | 09:55 AM
Rgd9664's Avatar
Rgd9664
There's always alot of parts on there. I search everyday and change the setting from best match to newly listed because I look so often.
joezzz
Jun 21, 2019 07:04 AM
RedTaurus94
Jul 16, 2018 11:11 AM
Nathan2115
Dec 11, 2016 12:44 AM
rrkF-1
Dec 10, 2012 04:04 PM
ditto
Sep 3, 2004 11:32 PM
