altonator wiring
Old Feb 29, 2012 | 02:56 PM
cheddar89's Avatar
cheddar89
altonator wiring
I recently put a 86 351 in my 63 and was wondering if i had to wire it through the voltage regulator or if it had one built in and how to wire it up any help would be appriciated thanks
Old Feb 29, 2012 | 10:44 PM
William's Avatar
William
Alternator
Use a Ford 3G internally regulated 100 amp. Google "Ford 3G installation" and see what pops up. Ebat seller has these alternators and install kits for about 100 bucks. Eliminates the regulator lots of rotten wiring and is a simple install. Check the technical section for similiar installations using a Delco 12SI.
Old Mar 1, 2012 | 09:37 AM
rustywheel68's Avatar
rustywheel68
it would depend on what alternator is on the '86 engine...i'm not sure when they switched from the 1G over to the 2G. 1G would have an external regulator, 2G would be internal.
In any case- I agree with William. Go with the 3G.
But if you need to use what you've got, this page has pics of the alts for identification, and also the wiring diagrams.
Fuel Injection Technical Library » Alternator Files
19fifty4
May 25, 2012 11:18 PM
DGMFORD
Aug 22, 2010 02:12 PM
ltfox
Jul 29, 2009 01:25 PM
56effiex
Aug 21, 2004 01:02 AM
heartland_kc
Sep 17, 2003 09:17 PM
