Should I go to 295/65/18 from 275/70/18?
F350 diesel getting a new set of GY Duratracs. Currently running OEM size 275/70/18 and considering the 295/65/18. Didn't get great wear from the 1st set but really like the tires. I'm wondering if a little wider tire might wear better and give more tread life? I'm not sure if there's much a guy can do to get more life from a tire with a heavy truck that has good torque, pulling heavy loads periodically through the year? Anybody running the 295/65/18's on the factory 18" that would give them a thumbs up or down?
I only have 14,000 on the old set on the truck - they are down to about 11/32" from 18/32" new tread. I punctured one on the sidewall last weekend on the rear and decided to replace all 4 instead of keeping one new tire that is about 1/2" diameter larger. The tire shop ended up giving me a lot of credit for the 3 used tires too, so the whole set of 4 new ones is less than $500 installed so I couldn't pass it up. The tire shop said this morning that the 295's are back ordered and take a while longer to get than the OEM 275 size so I'm just going to stick with stock size again.
I clear 295/70R18s on my 07, basically identical to your 05. The tires bulge some in the middle, that's the downside of a wider tire on the 8" rim, the small sidewall difference isn't enough to make yours that much worse. But enough guys here run 305+mm wide on them to shout me down and say go for it when I say stuff like this.
Edit: Didn't see the update before I posted, good luck with the new stockers
