Sponsored by: Real Truck
fuel guage
Old Feb 28, 2012 | 05:52 PM
steve1954's Avatar
steve1954
fuel guage
05 f-250 5.4 auto 4x4, extended cab long bed. Tha fuel guage stopped working about 3 months ago, but hasn't affected the running of the truck, forgot to mention 177,000 miles. My question is ,Is it possible the float or whatever they use could have come off? As I understand the fuel pump and sending unit are all one part, any suggestions?
Old Feb 28, 2012 | 06:02 PM
Tact's Avatar
Tact
I don't know if my comment will help, but my F250 is diesel, and when my gauge quite working I put Lucas fuel treatment in the tank. My understanding is that it helped clean the contact on the float/sending unit. It cured my problem almost instantly. It might be worth a try to add some gas treatment to your tank.
Old Feb 28, 2012 | 06:03 PM
PA-Mark's Avatar
PA-Mark
Unlikely the float poped off... take the wire off the top of the tank. find which is the sending unit lead and ground it to the frame... if the guage peggs out to full you need a new sending unit, even if it is part of the fuel pump... If you dont wish to replace the whole thing, you can use your Odometer/ trip meter as a temporary fuel guage untill you wish to do the repair. If the guage does not pegg out, you have an open circut between there and the guage, or the guage itself
Old Feb 28, 2012 | 06:05 PM
PA-Mark's Avatar
PA-Mark
this is a good point... if you life in an area with ethenol added to your fuel, it can cause problems for the contacts... I forgot about that
Old Feb 28, 2012 | 06:20 PM
Tact's Avatar
Tact
I would add some Chevron Techron Plus Fuel System Cleaner to an almost empty tank and then fill it up. You may have to do this a couple of time, but it may help on the first fill. It's worth a try before you tear into your tank.
Old Feb 28, 2012 | 06:32 PM
Fordfanatic4life's Avatar
Fordfanatic4life
add a couple of bigger bottles of fuel system cleaner.. it might help break the rust/scale off the float..
its kinda of a common problem..but its also possible the sending unit has died all together..
fuel treatment is a cheap fix if it works thou.
add the bottles then find a ruff road to bounce around on..
89FordDriver
Dec 9, 2014 11:06 AM
Supercab
26
Feb 2, 2013 09:28 PM
1970f2504x4
Sep 22, 2004 04:29 PM
grnacres
1983 - 2012 Ranger & B-Series
Dec 8, 2003 05:20 PM
