Testing the pump
Old Feb 28, 2012 | 03:12 PM
diablodude64's Avatar
diablodude64
Testing the pump
I am getting diesel fuel in my crank case and I noticed that the area surrounding and including the mechanical lift pump are pretty much soaked. The truck had been sitting for a while before I bought it so I have been going through and making it road worthy, so I will probably replace the pump for peace of mind along with all of the o-rings for the injectors.
My questions is, after pulling the lift pump, is there a way of testing it?
Thanks, Kyle
Old Feb 28, 2012 | 04:01 PM
Aune163rd's Avatar
Aune163rd
Not really, if its putting the diesel fuel in the crankcase, its bad...its probably the diaphram inside the blasted thing.
Old Feb 28, 2012 | 05:37 PM
joshofalltrades's Avatar
joshofalltrades
if it leaks, its junk. if you ignore the fact, your engine will be too
Old Feb 28, 2012 | 06:53 PM
Aune163rd's Avatar
Aune163rd
x2 with what josh said!
Old Feb 28, 2012 | 09:40 PM
diablodude64
New pump installed. That was a bitch....
Old Feb 28, 2012 | 10:00 PM
joshofalltrades
when i did mine, it took like an hour just to get that darn steel line to screw into the pump. if i ever have to do it again, i'm going electric
Old Feb 28, 2012 | 10:27 PM
greywynd's Avatar
greywynd
Some guys reach down from top to do them, I always do them from underneath. I have found that I place the pump in the hole, then start the steel line fitting, then tighten everything up. Gives you more wiggle room to get the thread started.
Old Feb 28, 2012 | 10:31 PM
joshofalltrades
it looks darn near impossible to even touch it from the top! mine was done from the bottom, i bolted it firmly to the engine first, then got to the lines. having the wiggle room might have helped a lot
Old Feb 28, 2012 | 10:36 PM
diablodude64
honestly the worst part was removing the old gasket!
Old Feb 29, 2012 | 02:12 AM
greywynd's Avatar
greywynd
A sharp scraper or putty knife works best, but be careful you don't gouge the cast iron of the block. Being a toolmaker, my scrapers are almost as sharp as my knives though, so it tends to take off old gaskets etc pretty good.
Old Mar 1, 2012 | 07:39 PM
kowalski22's Avatar
kowalski22
random question, is it possible to have a MAJOR oil leak from the lift pump?
my new to me truck leaks very bad, it appears to be leaking oil from around the base of the lift pump but is very hard to see.
the PO recently installed a new LP, i wouldnt be suprised if it is leaking due to his "hack job" approch to everything he touched...
Old Mar 1, 2012 | 07:58 PM
joshofalltrades
that depends on how we define major, but yes, it can leak quite a bit. considering your view of the PO, lets say that the gasket was torn or folded as he installed it, or he forgot to tighten the bolts properly, then every bit of oil that splashes up there leaks out.
first thing i would do is clean that entire engine bay so you can really see where the leak is. from there, if the pump appears to leak, go buy a new one, pull off the old one, and inspect it. if there's something obvious like a torn/folded gasket, replace just the gasket, otherwise replace the whole pump
freightdogfred
16
Jan 30, 2019 09:15 PM
Nick bass
Aug 12, 2012 09:30 AM
McQ
Jun 22, 2012 07:20 PM
svtcobra041
Jan 7, 2010 07:16 PM
bio-d
May 10, 2007 10:03 AM
