Just tach welded mine open and gutted the rest. Put a bolt through the hole where the armature went through, with my old pedastal gaskets. Tightened it up and messed up the threads so It can't come loose. But if i could I would have threaded it with a tap and plugged it like everyone else did. just giving ya some more options.
Yeah have to rebuild the pedistal anyway cause its leaking so yeah I'll just tig up all the holes I dont need
From what i have read just remove snap ring and plug, remove actuator, either weld the little hole shut or tap it to whichever pipe thread is handy, and install plug and snap ring.
That easy huh? And will welding that hole **** interfere with the oiling of the turbo?
No it should not. I will be tackling my turbo hear in the next coulple of days, i will post my findings if anyone is interested. I too wondered what seperates the oil passage to the turbo itself from the EBPV. AS far as i can tell if the ebpv's electrical conection is unhooked and all a person does is plug/weld the hole where the rod comes out there should be no ill affects towards the turbo's oil supply. Either way i will do a small write up after i am finished. I hope to get a darn camera soon so i can post pictures. I have tried a few times with my "smart phone" but havent had any success.
Right on. I might leave my butterfly intact, reason being i am gonna look into an air cylinder that i could possibly actuate the the butterfly with. I know it sounds dumb but it would be cheaper than buying a real exhaust brake.
