Sponsored by: Real Truck
Close Call today
Old Feb 27, 2012 | 03:34 PM
Lastwagen's Avatar
Lastwagen
Close Call today
Sometimes when I brake, my foot also touches the accelerator pedal. If my foot is positioned just a little too far right on the brake pedal and if I brake very hard at all then it also pushes the go pedal.
On the way to the post office this morning someone decided to stop for a yellow at the last second. I braked but my truck kept going. The harder I pushed, the harder it accelerated, so much so that it started spinning the tires. I couldn't feel that I was pressing on the accelerator but quickly realized that I would have to bring my left foot into action on the brake and removed my right foot completely. (Consider that I was just a foot or so off her bumper by this time so I couldn't just let up on the brake)
I know how to "heel & toe" my corvette to rev match when shifting so I'm not just dumb or spastic. It seems that the brake pedal should be higher so as to not let this happen. The truck has the "pedal adjust" but they both move together. Any thoughts?
Old Feb 27, 2012 | 03:40 PM
Boss08v10's Avatar
Boss08v10
I have done this 3 time in my 08, once at a RR crossing with a train coming
Got my heart rate up there for sure.
Old Feb 27, 2012 | 03:44 PM
Maxium4x4's Avatar
Maxium4x4
Interesting, must be different than my 03, plus I have big feet...
Old Feb 27, 2012 | 03:45 PM
Kajtek1's Avatar
Kajtek1
Is the lack of program for disconnecting the gas when braking what killed several people in Toyotas and Lexuses?
I think that should be reported to authorities?
Old Feb 27, 2012 | 04:11 PM
Sand_Man's Avatar
Sand_Man
I agree. Call the DMV and tell them you need a driver's test. The space between the pedals is huge and I cannot imagine not knowing you're pressing the gas and brake at the same time. Seriously.
Old Feb 27, 2012 | 04:39 PM
TexasRebel's Avatar
TexasRebel
The distance between the brake and accelerator pedals in these pickups is not sufficient.
In my Chevrolet, I could fit my whole foot (7-1/2 E) between the pedals (manual on both, so the brake is not the wide brake).
In my '08 Ford, I can mash both pedals down with ease. I have it easy because my clutch is in, and my hand is on the shifter... automatics might have a bit more trouble.
Disconnecting the accelerator while braking is a horrible idea. The Toyota/Lexus problem was with disconnecting the cruise control.
As far as not knowing, the drive-by-wire accelerator they put in these days takes very little effort to press. Much less than the brake, so if you are putting out braking effort to the pedal, you'll never even fell the accelerator... you just hear the engine wind up.
Old Feb 27, 2012 | 05:29 PM
smotrs's Avatar
smotrs
Your wearing the wrong shoes.
Old Feb 27, 2012 | 05:44 PM
A/Ox4's Avatar
A/Ox4
9 ECHO 1
Ive heard of this before... I tried it once and couldnt do it with out being awkwardly positioned...
Old Feb 27, 2012 | 10:35 PM
Boss08v10's Avatar
Boss08v10
Simply not the case, I never once had it happen with my 04 or 06 f350 and three times now with the 08. Something changed there is no doubt in my mind. Just have to more mindful and move my right foot over to the left more is all.
Old Feb 27, 2012 | 10:37 PM
Boss08v10's Avatar
Boss08v10
what he said
Old Feb 27, 2012 | 10:48 PM
Hotpocket's Avatar
Hotpocket
i did the same thing in my old 92 mercury cougar but this is NOT a problem with my super duty
Old Feb 27, 2012 | 10:52 PM
Kajtek1's Avatar
Kajtek1
Toyotas killed people because gas pedal got stuck by the carpet and with the absence of SAFETY feature of disconnecting the accelerator while pushing the brake the drivers were not able to stop the car. It is a bit more complicated, but bottom line is that other brands do have the right program and never had the problem the Toyota did.
Superduty with its big pedal not likely will have carpet holding the gas pedal, but we did have a recall for wrong wiring on CC didn't we?
I had my close call when my truck parked for 2 weeks stared to smoke under the hood when I was 1 hr away from home. My wife could not pop the hood, so all she could do was wait with phone and fire extinguisher in hand. Turned out 30 amp fuse allowed the wiper motor to melt down before disconnecting the power.
Old Feb 27, 2012 | 11:27 PM
Boss08v10's Avatar
Boss08v10
Why could they not just put the dang thing in neutral? I have taught both my teenage boys this if they were to ever have a throttle cable hang up or something. I just can not understand why these toyota drivers rode the thing out into whatever they hit. Either stick or auto you can still put the thing in neutral right?
Old Feb 27, 2012 | 11:28 PM
Sand_Man's Avatar
Sand_Man
If you think the space is too tight, I wouldn't try driving a manual-trans performance car. Or any car until you find the problem...
Old Feb 27, 2012 | 11:37 PM
Kajtek1's Avatar
Kajtek1
The smart programmers made it impossible to switch the gears at full throttle.
Bear in mind that digital vehicles do what factory programmers told them to do, not what the driver wants.
My main truck is having manual transmission, but I am planning to get on my new purchase with automatic and see how it works.
Those things sound scary.
