reverse Sensing System
Old Feb 27, 2012 | 10:49 AM
GunnyBeaty's Avatar
GunnyBeaty
MY 04 Excursion limited has 154k miles on it. Up until about 2 weks ago the RSS worked great. Then the light on the dash that turns the RSS off when you are backing up a trailer was intermittenly on/off then it stayed on the whole time. The switch doesnt lock in one position. Like the clicker is bad. I spent $28 and got a new swithc hoping this would fix the problem and Momma could back her school bus up with no problems. Not so. I checked out all the sensors and when you get in front of them individually you can hear them clicking. but the switch is still stuck in off. I disconnected the battery and reset the system and it still doesnt work. I cant find any skematics in my Haynes/Chilton manual for this system. there is no fuse for it in the owners manual. WTFO!
Any suggestions or ideas?
thanks
Old Feb 27, 2012 | 10:54 AM
Sunline Fan's Avatar
Sunline Fan
Excursion Fleet Manager
I've heard lately of people having the speaker go dead for the RSS, which trips the light to let you know there's a problem. The speaker is located near the right rear vent window motor, behind the small cutouts in the plastic.
Old Feb 27, 2012 | 12:15 PM
robert_l_ross's Avatar
robert_l_ross
Makes total sense...if the speaker or connector is on the fritz, the circuit can't be completed...the light must be based on the complete circuit (or lack of)...
Before buying a new speaker, maybe check the pick and pull lots...I haven't heard of too many if these systems dying out, so old speakers have a good chance of still working.
Old Feb 27, 2012 | 01:19 PM
GunnyBeaty's Avatar
GunnyBeaty
Maybe i'll hook a 6x9 to it!
Old Feb 27, 2012 | 01:25 PM
robert_l_ross
HA! You'll go nuts - it'll sound like a rave in the back!
Old Feb 27, 2012 | 01:29 PM
Fuha's Avatar
Fuha
just make it a 15 and call it done
Old Feb 27, 2012 | 09:41 PM
pdombrowicki's Avatar
pdombrowicki
The parking aid control module is also located in the jack compartment mounted underneath the rear air box mounted on D pillar. If you need a wiring diagram let me know. I have a ford one.
Old Feb 28, 2012 | 06:14 AM
GunnyBeaty's Avatar
GunnyBeaty
The wiring diagram would help tremendously. I am an Avionics guy in the Marines and i try to get a meter and troubleshoot the crap out of everything before i pay someone. Email it to jeffrey.beaty@usmc.mil. Thanks man.
Old Feb 29, 2012 | 10:14 AM
GunnyBeaty's Avatar
GunnyBeaty
So I took off the panel and pulled out this little speaker. couldnt see anything exactly wrong. OHMd across it an dit was open. Speaker bad. Add 1 6X9 speaker and you get ...... A working system. Thanks for all your help. now if i can just find one of the replacement speakers so I can take the 6X9 out of the jack compartment.
Old Feb 29, 2012 | 11:32 AM
Nicmike's Avatar
Nicmike
Veteran/Sheepdog
Too funny, Gunny. I was avionics in the Navy. See my avatar. I did my h-53 training at New River back in the mid 90's. I hated that place....the 6x9 had me laughing. Typical "tron" solution!!!
Mike
Old Feb 29, 2012 | 12:15 PM
GunnyBeaty's Avatar
GunnyBeaty
98-02 I spent at New River. I had a blast. Well you know how redneck ingenuity goes mingled with some AVI know how.
Old Feb 29, 2012 | 11:08 PM
Nicmike's Avatar
Nicmike
Veteran/Sheepdog
Yes. I sure do....LOL
Old Mar 1, 2012 | 11:16 AM
GunnyBeaty's Avatar
GunnyBeaty
Thanks again for all the help. I did some research and the parts sotres have nothing for the reverse sensing system but i found the speaker online through Allied Electronics ( ALLIEDELEC.COM) for $1.80 . the shipping cost more than the part. but i should have it in 2 days and can pull the 6x9 oout of the jack compartment.
Old Mar 1, 2012 | 05:11 PM
robert_l_ross
You sure you don't want to rig up an amp to it and use it as an external backup alarm?
Old Mar 2, 2012 | 06:09 AM
GunnyBeaty's Avatar
GunnyBeaty
If i was a computer geek i would do that and instead of beep beep it would say " Jackass I'm backing up . MOVE!"
