Can't remember how to remove "cone" nuts
Old Apr 25, 2003 | 08:53 AM
Lamo26's Avatar
Lamo26
Angry Can't remember how to remove "cone" nuts
Hey all-
Got new springs so I decided to pull front and rear difs to clean and paint. Rear came out just fine, 'cept for a sticky nut on the E-brake!!! Anyways, got the brake lines off the front, the hydraulic lines from the steering cylinder came off fine, now I'm left with the steering linkage that attaches to the drivers left hub, on top. I got the nuts off but at the bottom of the studs there is a "cone" nut that holds the bracket to the hub. For the life of me I cannot remember how to remove these !
Any idears out there?
Thanks, Bob on the Oregon Coast.
1975 F-250, 428 CJ
Old Apr 26, 2003 | 09:58 AM
aldridgec's Avatar
aldridgec
If its what I'm thinking of, they are cones that press into a cone shaped reciever around the stud. The nut presses the cone into the metal. If thats it, the I just use a hammer to tap the metal and loosen the cones.
Old Apr 28, 2003 | 08:27 AM
Lamo26's Avatar
Lamo26
Yeah, those are the ones, I'll be damned if I can get those bad boys out. Tried tapping with a hammer, no luck. Gonna try heating them up a bit and quenching with water. Wish me luck.
Bob
Old Apr 29, 2003 | 10:42 AM
Boss_358's Avatar
Boss_358
I had a friend show me the heat and water trick a while ago. He called it, "Shock Therapy."
big ole ford
Oct 20, 2012 06:35 PM
nothercrash
Mar 8, 2012 05:57 PM
dieselzen
Oct 4, 2011 08:53 PM
Fishin76
2004 - 2008 F150
Jun 13, 2010 01:23 AM
Fishin76
Offroad & 4x4
Nov 18, 2008 11:25 AM
