Front Sway Bar Bushing Replacement (with pics)
#97
How did it go ?
I was looking at the pictures of the swaybars in my haynes manual, and it shows the setup for a 2wd is different in the front.
The pictures are not great in the haynes manual so I Was wondering:
Are the end links the same on a 2wd ? I can't see.
I did notice the swaybar to frame brackets have cracked and dried out rubber in it badly.
#100
Anybody ever get a set for 2WD that fit?
I ordered mine 18 months ago and they have too much material
which keeps them from fitting. I've been debating cutting down
the excess since nobody seems to have found a solution for 2wd?
Bought from RockAuto: Raybestos 34.4mm for RWD 5501535
The picture shows there is WAY too much material between the
hole for the swaybar and the flat surface that would be against the truck.
http://www.rockauto.com/getimage/get...97-0&width=450
#101
#103
#104
#105
Going to remove the existing swaybar and endlinks this weekend and remove the endlink bushings.
