Where is the best place to find hub centric wheels? I have check the usual sources, but it seems that the wheels I like are never hub centric. Any ideas?
Hub centric wheels are indeed harder to find. Alot of guys run lug centric wheels with little or no problems. Use the correct lug nuts for the application.
I agree. If your working your truck its a must to keep it as heavy duty as possible. Look for forged wheels as I believe they are rated to carry higher weights. You should be able to find something with Google. No?
I just started looking, checked eBay and a couple other places. They are available but not the style I like. I will keep looking and I am in no rush.
im in the same boat and im having a hard time as well. nothing against black wheels but is it me or is there like a million of those things out there???
So far the only place I have found that has hub centric wheels is American Force Wheels. Their website says nothing about hub centric, so I called them and they said they do make them in fact all their wheels are made to order so hub centric is not a problem. National Tire did have a 20x9 wheel available but I am looking for a 20x10.
