Fuel pump knocking noise? Wrong type arm?
Old May 1, 2003 | 09:28 AM
chissler's Avatar
chissler
I think I've got it figured out. Your pump looks just like a 238. Application says: 63-64 ford fullsize (car) w/ 2bbl carb. Hit the store up for a picture and see what you think.
Old May 1, 2003 | 10:54 AM
ADSf100's Avatar
ADSf100
AbFitch,
I agree that something may not be original. That's why I'm trying to ID the old pump. I figure that a new one with the same arm (lever) configuration should work without the knocking noise.
Old May 2, 2003 | 03:55 AM
pat67shorty's Avatar
pat67shorty
A few years ago I replaced the fuel pump on my 352, and noticed that the arms were different. I little piece of paper in the box said: Warning! Ford F.E. and Windsor fuel pumps will physically bolt in place of each other, but using an F.E. pump in a windsor will cause severe damge. I found that using a small block pump in an F.E. will pump fuel, but it makes noise and pumps less. I found that someone had put a small block pump into that 352 sometime in it's life. It was quieter after I put the replacement pump in...
Old May 2, 2003 | 08:43 PM
1976 ranger's Avatar
1976 ranger
The part number from Carquest for my 360 motor was Fp 6676.
I bought it because the original went bad. I replaced it two week later with a holley as i put in a cam and bigger carb. I believe i still have the pump I can take a look tommorrow and see what the arm looks like.
David
76 Ford F250 Highboy 360, F427intake, Msd 6 offroad ignition,
Dyno max headers, Edelbrock Performer
Cam
garrett_browning
Jan 3, 2025 11:05 AM
Jymmm
21
Apr 3, 2019 12:52 AM
BigBlueBomb
Mar 4, 2014 01:46 PM
dothedew192
Jan 10, 2013 09:16 AM
jamlove
Dec 11, 2003 11:52 AM
