stuck egr valve
Old Feb 26, 2012 | 08:24 AM
Super Duty Daddy's Avatar
Super Duty Daddy
stuck egr valve
I started with the process of removing parts to change my oil cooler yesterday. Im going really slow and cleaning everything as I go. I took the week off from work so, that I wouldn't have to get in a hurry. Does anyone have a link or suggestion for the removal of a egr valve that is stuck? It is stuck because it is so gunked up inside! Thanks in advance.
Old Feb 26, 2012 | 09:08 AM
w_huisman's Avatar
w_huisman
After you remove the two mounting bolts, can you twist it at all? If so, twist it enough so the bolt holes are clear, run a 10ga. wire through both holes so as to create a handle to pull on. Then put a pry bar through the wire handle and pry straight up on the valve against the intake elbow.
bebeard
Sep 9, 2011 12:09 PM
AndeyHall
May 9, 2011 10:04 PM
URDADDY
Apr 7, 2011 07:16 PM
y0manda
May 11, 2010 01:50 PM
eliwho
Jan 7, 2007 04:47 PM
