Confirm hard line size for Brakes and Fuel..
Old 02-25-2012, 06:53 PM
checksix's Avatar
checksix
checksix is offline
All,
I'm getting ready to order bulk stainless tube and connectors for my brakes and fuel lines.
Is it OK to use 3/8" for both the brakes and fuel line?
Truck is a mostly 79 crew cab 4x4 with 460 and C6.
Thanks.
Old 02-25-2012, 07:55 PM
400 .040over's Avatar
400 .040over
400 .040over is offline
3/8 is way to big for brake lines, for brake lines use like 3/16
Old 02-26-2012, 01:09 AM
tbear853's Avatar
tbear853
tbear853 is online now
Received 1,295 Likes on 1,095 Posts
X 2 !
Old 02-26-2012, 10:10 AM
Blue and White's Avatar
Blue and White
Blue and White is offline
Agree as posted... 3/8" fuel and 3/16" brake lines as original.
The 3/8" line would not hold the +/- 1000 PSI of the brake system.
SS brake lines are a "bear" to flare and seal. It takes a high end flaring tool to make the double flare and even then they can be hard to seal because the ss is so hard the fittings don't seat as well. A standard "better" quality parts store flaring kit won't do it.
If you want ss brake lines I'd suggest a pre-made set from Inline tube. Cost is pretty reasonable, fuel lines also.
Personally, I stick with steel. Its easier to work with, lower cost and original lasted >30 years in my case.
Old 02-26-2012, 01:48 PM
checksix's Avatar
checksix
checksix is offline
Thanks guys.
I had access to nearly free bulk 3/8 tube and was hoping to use it for all hard line. I'll go ahead and buy the proper 3/16" for the brakes.
KsHighboy
20
01-10-2018 03:48 PM
pholmes350
13
11-30-2017 10:41 PM
ospreyguy
16
11-09-2010 12:10 PM
charles09
01-31-2010 02:59 PM
badass truck
03-22-2004 11:27 PM
Quick Reply: Confirm hard line size for Brakes and Fuel..
