that was stupid... starting 351w with no trans attached?
One secret I use on installing a trans like the big e4od is get some 6in by 7/16 bolts. I cut the heads off and I put one on each side if the block second hole down. they make excelent guides.
Cam break in.Did the factory do that to my Ford? I think not.
i got my atv jack back from my friend i think im just gonna pull the trans and remove the torque converter. get to do that after work tonight... ugh
Your just wasting your time, pour 15 quarts of atf in and fire it up. Your trans isn't working and there will be a film of lube throughout anyway to keep things lubed till the pressure builds which will not take long.
If you are really really worried about it unbolt your torque from the flexplate and slide it back from the engine, should be enough clearance to run the engine this way.
Scott
Scott
Andrew LaFrance
02-17-2019 07:36 PM
dragstang86
10-29-2011 09:53 AM
ford390gashog
04-10-2004 09:00 PM
