trying to post
Old Feb 25, 2012 | 09:40 AM
farmer ford's Avatar
farmer ford
trying to post
i was needing to put a picture in my thread to ask what a certain electrical component is. i see so many of you doing it but i dont know how. would any one here walk me through it? thanks
Old Feb 25, 2012 | 09:55 AM
Iallwork's Avatar
Iallwork
First I click userCP (top left). Then click pictures and album ( left side). Then make and name a album. Then try to upload pics to that. You will probably have to re-size them before they will upload. after they are in your album then you can post them. This took me a while to figure out how to do this so don't get to frustrated. Let me know how far you get. There are other ways to do this but this works for me.
Old Feb 25, 2012 | 10:01 AM
farmer ford
thanks so much i will get on that
Old Feb 25, 2012 | 10:55 AM
farmer ford
thanks steve i got it done reps added
Old Feb 25, 2012 | 11:02 AM
Iallwork's Avatar
Iallwork
your welcome. You got that fast. Next you'll have to do you signature for the bottom of your posts.
Old Feb 25, 2012 | 12:10 PM
farmer ford
i used to have one and was going to change it. got it all deleted and never rewrote. i forgot til now. what is the ebpv gut? i didnt know u could get rid of that system?
Old Feb 25, 2012 | 12:26 PM
strokin'_tatsch's Avatar
strokin'_tatsch
I use photobucket. It's a little easier b/c you can upload however many pics you want. Your albums on FTE can only have so many pics in them. To post pics from photobucket, go to Image hosting, free photo sharing & video sharing at Photobucket and create a free account.
Upload the pictures to your photobucket albums. Click the upload bar at the top when your at the home page, then once you get to this page, click select photos and videos.
Pick which picture you want to upload, in this case I wanted to upload the screen shot I just took of the picture I posted above, so I select the picture, then simply select open and photobucket will upload the picture to your album. Once the pic has loaded, you can scroll down and give the picture a title or description or whatever.
Now, you've uploaded the picture and now you want to post it from photobucket to here. Go to your album and hover the mouse over the picture you want to post. When you do that, the pic will get a little bigger and give you some options of things to do with the picture.
What you want to do is go down and copy the IMG CODE and then paste the IMG Code here in the reply box on FTE. It will look like this
Now when you submit the reply, all those links with IMG around them, should appear as pictures, instead of text. That's about as simple as I can think to put it. If you have any questions, feel free to ask.
For some reason all those pics came out smaller than normal. Never seen that before, but if you click the yellow bar that says "click bar to view full size" or whatever, the pics get bigger.
Old Feb 25, 2012 | 01:09 PM
Iallwork's Avatar
Iallwork
EBPV gut is where you remove the butterfly that closes the exhaust to help warm up the truck. The valve is just after the turbo. I just removed the mechanical things and tac welded the valve open.
Old Feb 25, 2012 | 01:17 PM
Iallwork's Avatar
Iallwork
now that i think about it, I removed the insides of the arm mechanism and put a plug in it. I believe it was part of the turbo housing. I did mine when I had my turbo off to repair a leak from the O-rings under the turbo pedestal.
Old Feb 25, 2012 | 03:14 PM
farmer ford
o k i thought maybe had to do with the ebpv sensor cutting off fuel and keeping the smoke down. i wired my ebpv as a exhaust brake it is slow to activate but very effective
tony. b
Jun 1, 2011 08:38 PM
78 PEB
19
Jan 25, 2011 10:34 PM
Barndon
Feb 13, 2010 10:52 AM
fito1411
Oct 25, 2004 07:33 PM
sattie
2004 - 2008 F150
Apr 6, 2004 06:18 AM
