On sunny days around town, I turn it off.
Trying to add a bit of extra wear here and there on my conti's with a few aggressive take offs (no burn outs, just fast launches).
It doesn't help if you are stuck, I found out.
Best to turn it off then.
I think 4x4 low disables all three sytems automatically though.
Thats great to hear...I know my Sequoia traction control wasn't the greatest. (then it stopped working)
On my Tundra the traction control was so intrusive it would try to brake the wheels to a dead stop while I'm trying to apply throttle, so I would rapidly get burning rear brakes and a warning light. (I got out and they were sizzling because some snow landed on the brake discs.) Had to turn off the nannies (TRAC and the ABS-based "Limited Slip" feature) all the time to prevent that from happening. 4x2, so wheelspin is pretty much just expected, and often needed to get anywhere.
On the SD, it's not quite as intrusive, the ABS unit will only give short 'taps' of braking to the spinning wheel and it won't overdo it. Also, you'll likely have other features like a mechanical axle lock-up to help out.
On icy road conditions though, it will react faster to correct a fishtail or oversteer condition than any person can, so the implementation of this system in vehicles has its merits too. I'm not going to be one of those guys who hates technology in vehicles for the sake of it, and I'm glad safety systems have finally made their way to pickup trucks.
Well it sounds like it works a lot better on the SD. When I was in the snow with my Sequoia it made an awful sound when the traction control would kick in so not to mention it would want to stop the tire like you were saying...and when you are climbing a hill that does not help one bit! SO I would promptly turn off the traction control and let the tires spin at times.
Traction control
Works seamless enough that you hardly notice it is on all the time unless you turn it off. And the next time you start the truck it is back on.
Only time it is not automatically on is when in 4wd. System turns off when switching to 4wd.
Don't forget to play with the trailer sway control too! I used to think it would create drag and eat fuel but I gave up, I think it's all fine to just leave alone and drive.....
I meant turn it on and off and see if there is any change in economy or the feel of the drive. Trial and experimenting with it on and off is all I meant.
Traction control
Mine doesn't turn off in 4x4H. Does yours?
4x4L, yes.
