1978 - 1996 Big Bronco
Big Blue's Havin some Probs!
Old Apr 24, 2003 | 07:54 PM
bigbluebronco43's Avatar
bigbluebronco43
Hey all I've been having problems with my bronco and i'm pretty sure its the TPS. This thing looks simple to install, just remove the throttle body and basically plug the new one in. BUT i looked in my haynes manual and it said something about adjusting it electricly or something...Any help here would help because it would be a lot easier to just put this thing in and drive away hehehe i know thats not going to happen!
Old Apr 24, 2003 | 08:56 PM
thelonerangerxlt's Avatar
thelonerangerxlt
Some of the early models were adjustable. If yours is, just mark both TPS's and the throttle body, and install the new one in the same place.
Are you sure the TPS is bad? How many miles on it? The TPS is easy to check if you have a multimeter.
Old Apr 24, 2003 | 09:48 PM
bigbluebronco43
I don't have a multi meter, its a 302 5.0, with 164,000 miles on it. I'm heading to bed but will post whats been going wrong with it tommorrow, i've jsut returned from the hospital and am tired out. But i had it checked at an autozone back in november and the guy said it was the TpS. Thanks for the help, talk to ya tomorrow.
Old Apr 25, 2003 | 12:02 AM
steve83's Avatar
steve83
You can get a decent multimeter at Sears, Radio Shack, or Wal-Mart for ~$15 and a Haynes manual for $12 that shows exactly how to test all the sensors & actuators. Plus, you can pull the codes yourself free anywhere with only a paperclip.
Old Apr 25, 2003 | 02:06 AM
greystreak92's Avatar
greystreak92
The adjustment is easy enough considering the resistance should be zero ohms at WOT.
Old Apr 25, 2003 | 08:01 AM
steve83's Avatar
steve83
The idle adjustment (1.0V) is more critical than WOT.
Old Apr 25, 2003 | 10:00 AM
bigbluebronco43
so at idle it should be at 1? I already have the manual, i'll have to pick up the meter this week and try this. So this should pretty much be a straight forward fix. About reading the codes with a paper clip, how do i do that, just place the clip so it bridges the two holes in the plug or something and listen/watch the check engine light? You gotta love fords, a paper clip will tell you whats wrong with it
Old Apr 25, 2003 | 09:04 PM
steve83's Avatar
steve83
Click on the words "pull the codes" in my previous post.
