MBRP exhaust
Old Feb 24, 2012 | 04:14 PM
fixxxer-upper's Avatar
fixxxer-upper
FTE Fan
Originally Posted by Ian123
I couldn't imagine doing this install myself. There was a lot of times when I needed an extra set of hands but overall it wasn't too bad
I lack mechanically inclined friends. It was a lot of "back" time and supporting parts with the knees! But, it got done. The lift on the truck made access a ton easier.
Old Feb 24, 2012 | 04:17 PM
Dans2Fords's Avatar
Dans2Fords
Mine only has the Fabtech leveling kit on the front to make it the same height as the back. I actally really like it. You get that feeling of it being lifted, but it's not actually.
I have a friend that can help hold the exhaust while I work it in, but I just wasn't sure if it was as simple as unbolting it from the turbo (above or from below??) unhooking it from the hangars and then putting the new one in.
Old Feb 24, 2012 | 04:21 PM
fixxxer-upper
FTE Fan
yes, it is as "simple" as unbolting the parts, but that down pipe will give you fits. Installing the new system to the turbo will be easier with the extra set of hands. Leave all of the parts hand tight for adjustments later.
Old Feb 24, 2012 | 05:20 PM
abealex's Avatar
abealex
I went with the 4" MBRP (with muffler) and I am happy with it. Sound is not that noticeable inside the truck. I think the turbo output is 3-3.5", so I'm not sure there would be a big difference in power between the 4" & 5". I would recommend using band clamps like these - JEGS Preformed Stainless Steel Exhaust Band Clamps - JEGS instead of the ones that come with the kit so future disassembly will be easier.
You will probably need adapters welded on to the cat to get the stock size up to 4".
Old Feb 25, 2012 | 11:33 AM
King-bRanch's Avatar
King-bRanch
I have the Dual 4" System w/converter re-installed (NC has annual inspection) & love it !!
The install was easy, everything fit perfect (all hangers pre-welded & clamps provided) the only thing that sucked was getting the original down-pipe out w/out cutting it, that was tricky & involved some cuss words..lol
I love the sound, its very aggressive but not too loud (above 2k RPM & she is a lively soundin Devil)....Thanks MBRP
Yes i know it needs a bath
Old Feb 25, 2012 | 08:38 PM
pmoney1983's Avatar
pmoney1983
I'm not so much concerned about loudness. I do have to be a little careful because if it's too loud, the police will want to check to make sure I'm legal. I was looking at MBRP's turbo back system for the cat and then get the cat delete test pipe for when I'm not having to get it smogged.
As NWA would say "Man! F*** tha police!!!!!". Lolololololol!!! Sorry impluse. But thats how i feel about these little podunk towns like the one i live in with the police being bored.
Old Feb 25, 2012 | 10:19 PM
pmoney1983's Avatar
pmoney1983
Is that a blue chevy i see in that pic on the right?
Old Feb 26, 2012 | 11:50 AM
Dans2Fords's Avatar
Dans2Fords
My only concern is if I have to install the stock cat, how much cutting will be invovled. Is the stock system 3 1/2" or 4"? I am heading towards doing the test pipe and then putting the cat in for smog testing then swapping it back out.
Old Feb 26, 2012 | 12:08 PM
pmoney1983's Avatar
pmoney1983
3 1/2"on the stock pipe. Thank god i live in a part of my state that doesnt do the testing. If i did i wouldnt mess with the CAT just cause i wouldnt want to have to get under my truck just for inspection purposes.
Old Feb 26, 2012 | 12:17 PM
Dans2Fords's Avatar
Dans2Fords
Ours is once every 2 years for our DMV renewal on the vehicle. So about an hour for removal and re-installation is worth it for 2 years IMO.
Old Feb 26, 2012 | 12:47 PM
Proracing's Avatar
Proracing
I have a magna flow 5" system with a 3.5" down pipe and took out the cat and muffler. it's very easy to put the cat in and out if you need to for emissions. Either way I should of gone with a smaller down pipe as I lost alot of torque.
Old Feb 26, 2012 | 12:48 PM
Dans2Fords's Avatar
Dans2Fords
If the stock downpipe is 3.5", how did you lose a lot of torque keeping with the same size?
Old Feb 26, 2012 | 01:28 PM
  #28
Tylus's Avatar
Tylus
MMNC (SS)(Ret)
Veteran: Navy
He didn't. The turbo maintains all the back pressure the motor will ever need
A bigger downpipe/exhaust will only help lower EGT's...to a point. Then you are just putting big pipes on for no reason
The stock downpipe is 3.5"...but it's crimped and has flow restrictions
Old Feb 26, 2012 | 01:37 PM
  #29
King-bRanch
LMAO that u picked that out of the pic...Yes its my father-in-laws gas'r that he "tries" to pull a 5th wheel with.
Old Feb 26, 2012 | 01:40 PM
  #30
King-bRanch
Very EASY...you make 1 cut 4 inch's or so from each end of the Converter, i used a sawz-all & it literaly took 2 min, the pipes MBRP supplys fit to the Cat perfectly if u order the kit thats designed to re-install the Cat with as i did
