Edge CS or CTS?
First thing you should do is read all you can about tuning here on FTE. Learn the pros and cons. There are no free lunches, and there are no risk free tuners/tunes.
The Insight is harmless, as long as you remember to look at the road too.
I have the CS and if I could do it over again I'd spend the extra $100 for the CTS. I originally bought the CS not only to save money, but also because it fits better in the pod and looks factory. People always ask me if my truck came with it.
On the other hand, the CTS is nicer because you can display three "analog" style gauges, plus two smaller ones. On the CS, you only get two analog and one smaller gauge. Monitoring 5 things is much more useful than just 3. Although I should mention the CS can display up to 8 gauges at once if you don't want any of the analog style (refer to the picture posted by bpounds).
Technically you can add anything to the CTS, it's just a matter of $$$. Fuel pressure and exhaust gas temp (EGT) are the most common two added, but you could probably do a probe for low pressure oil and a few other things. It's just the 2" gauges are normally cheaper, and the most a CS or CTS can show is 8 at a time, so putting up ECT, EOT, TFT, Volts, FICM V, EGT, fuel press, and boost maxes out the screen. If you want to show the sweep gauges, you're maxed at 5 on the screen.
http://www.edgeproducts.com/product.php?pk=158&pvk=443
http://www.edgeproducts.com/product.php?pk=160&pvk=445
http://www.edgeproducts.com/product.php?pk=159&pvk=444
That stuff is expensive. I have a 2" fuel press gauge, and a 2" EGT is going in soon. People say a mechanical boost is more accurate than the PCM calculation, and a real voltmeter pulls from a better place (V on the CTS lags something like .1-.4V behind checking elsewhere)
The only gauge I bought separate was fuel pressure. I picked up a glowshift for like $60 bucks or something, whereas the fuel pressure setup for the CTS cost $300
Technically you can add anything to the CTS, it's just a matter of $$$. Fuel pressure and exhaust gas temp (EGT) are the most common two added, but you can add a probe to do low pressure oil if you can wire a sending unit into a universal connector.
Editing to find links
Edge Products| Product
the edge website says the CTS reads enigine oil pressure?? is that not correct?
this is everything it says it shows
Accel Pedal Position, Barometric Pressure, Battery Voltage, Corrected Speed (03-04), Engine Coolant Temp, Engine Load, Engine Oil Pressure, Engine Oil Temp, Engine RPM, Engine Run Time, FICM Voltage, Gear with TCL, ICP Pressure, Injector Pulse Width, Intake Air Temp, Mass Air Flow, Mileage Coach, MPG Instant, MPG Average, TCC Duty Cycle, Time 0-60, Time 1/4 mile, Trans Temp, Turbo Boost, Vehicle Speed (04-07), Variable Geometry Turbo Duty Cycle
If you want some standalone gauges, EGT would be a good one. Fuel pressure would be another. That would free up two cells on the Insight, and save you the cost of the EAS expansion components. Some guys really prefer an analog Boost gauge over the digital version.
The Insight cannot do engine base oil pressure, because the 6.0 PCM does not monitor base oil pressure. You can do it with the EAS expansion, but it really isn't needed on our engines.
Edge (and Linear Logic who makes the scangauge) put up ALL the PIDS their products can pull, they don't always say the vehicle doesn't have the sensor to actually make it work. My car doesn't have seem to have trans temp, oil temp, or oil press.... but I'm looking into it
I like it, no problems. The ones and tens number jumps around, but the hundreds is stable. And they are all stable when it matters, like when waiting for cool down.
#29
#30
Not true.
I did the same with the Edge CS. The SCII cannot do EGT or Fuel Pressure. I would argue that with expansions, the Edge can do a lot MORE than the SCII.
But hey, they both are valuable tools, each with positives and negatives. No point in arguing which is best. I would like to own both. But the Edge would remain mounted permanently, and the SGII would be hidden in the glove box.
I cannot imagine why you would want to downgrade to an SGII now that you've already invested in the Edge. You'll take a bath on resale. But to each his own.
Also diagnosing HP oil leaks is pretty hard on this without the IPR pid. Yeah you can add fuel pressure and egt to the edge (I have the egt probe btw) but its retarded expensive for the fuel pressure setup. Again to each their own and we are all different. The edge would be farrr better if it had a x guage function. I would like to see my fan speeds and IPR values every now and then.
