Lifted 2wds???
#31
#32
if you want pics of a 2wd lifted truck you can just look at lifted 4x4s, just consider that a 2wd is about 2inches lower than a 4x4, but as far as actual lifting it goes the front is kinda easy sometimes or a serious pain, if you want a street princes that sees very light off roading like say just enough to spin the tires 2wd will be perfect, u'll get better mpgs than a 4x4 will. im not a big fan of lifted 2wds but ITS YOUR TRUCK, DO AS YOU PLEASE
#33
#35
theres a bigger difference in front and rear on a 2wd vs 4wd, think its like 23 inches lower in the front for a 2wd? might just be mine, but a 6 inch lift is different in a 2wd than 4wd, but like i said, to get the same results as a 4wd lifted truck u need to basically add 2 inches for the 2wd to equal it
#36
#39
#41
#42
In my opinion, I think lifting a 2wd is a fine idea. Many of the trails we have around here are unfortunately almost too easy in 4wd (if you're a really good driver and your off-road awesomeness isn't directly related only to a heavy right foot!)
For instance, my Samurai and I were such a great team that the local trails were a joke after I learned them. As such, I bought a stock '87 Blazer and drove the same trails just to make them fun again.
Driving a 2wd on trails will force you to be a thinking driver. Not just someone who pushes a button on the dash and hammers the gas pedal to get to the end of a trail. Sure, beating the crap out of a 4x4 can be fun but picking your way through a trail with a 2wd and becoming technically proficient and talented is even more satisfying... to me at least.
I keep having this recurring fantasy about trail riding and camping in an E350 van with a rear locker only. A rear locker and good tires will go a loooong way if you use your head.
Lift away bro!
Lift away bro!
#43
#44
Ever drive down the road after the season's first snowfall and notice all the "Four-By's" sitting in the ditch? Back to the driving school with you clowns!
A good driver can do, with a RWD truck, 90% of that he could do with a 4x. It has more to do with finessing the rear wheel torque and looking three or four turns ahead than it has to do with a front driveshaft, IMO.
Also, in some situations, a RWD truck is arguably BETTER offroad than a 4x because of the decreased turning radius. And you can't beat the "low-mount swing-away mirrors" our trucks have.
#45
+1000.
O yea, 6<8 I love my big heavy diesel... But if I ran a half ton I would want the 6 just for the durability.
