DSII (swap) distributor spring replacement?
Old Feb 22, 2012 | 02:11 PM
minnesota-clint's Avatar
minnesota-clint
I'm doin the DSII swap on my 84, I6. I went to replace the smaller spring in the distributor and from what I can see of it, both springs look to be heftier than the replacement from Mr.Gasket, and not really sure which of the two would be considered "smaller". I have a A1 Cardone reman. distributor if that makes any difference. https://www.ford-trucks.com/forums/p...ictureid=93641 https://www.ford-trucks.com/forums/p...ictureid=93640 The silver looks "stiffer" and the black looks to have a bigger "loop", both look to be bigger than what I picked up.
Old Feb 22, 2012 | 07:42 PM
nevrenufhp's Avatar
nevrenufhp
Try em out and see. Then, you'll know right away if it's pinging at 1500 rpm. I run 2 light springs with the tabs bent out to stretch em a little. It has full advance at around 2k.
Old Feb 23, 2012 | 09:15 AM
gfw1985's Avatar
gfw1985
Cranky Old Guy
Here is the instruction sheet for the Crane canister and spring kit. This should help a bit.
File Type: pdf
1972-34ton
16
Dec 30, 2018 02:11 PM
carbo_nero
23
Mar 14, 2017 11:29 AM
10129
Feb 11, 2015 06:58 AM
fordeverpower
May 26, 2004 04:31 PM
Mike W
Dec 2, 2002 08:30 PM
