Centrifugal advance
Old Nov 29, 2002 | 09:48 PM
Mike W's Avatar
Mike W
Centrifugal advance
I have two Durospark 302 distributors that are only advancing 4 degrees at 2000 distributor rpm. These are clean and well lubed. I compared the advance setup to a points disributor that is working ok and don't see any difference or parts out of place. Vac advance is working. Any thoughts?
Old Nov 30, 2002 | 06:53 PM
Franklin2's Avatar
Franklin2
Centrifugal advance
Are you tearing them down and checking them to see if everything is ok? That's the one bad thing about Ford distributors. The weight mechanism is under the points plate.
Old Nov 30, 2002 | 08:17 PM
Mike W's Avatar
Mike W
Centrifugal advance
Yes, I even had the shafts out. They had varnish on them and were a little stiff to turn. Did a test today with one spring removed and was able to get full advance. I am testing on a distributor machine or it would be a real pain. I don't see how the advance will work with the heavy spring on. I looked at a points distributor that has full advance and the springs don't apply tension until the advance stop is almost reached.
Old Dec 2, 2002 | 08:05 AM
Quantrex's Avatar
Quantrex
Centrifugal advance
Factory advance curves are very slow and the springs are usually heavy for this reason.
Old Dec 2, 2002 | 10:14 AM
EPNCSU2006's Avatar
EPNCSU2006
Centrifugal advance
Old Dec 2, 2002 | 08:30 PM
Mike W's Avatar
Mike W
Centrifugal advance
One factory spec that I am using for a guide is for a 65 289 4bbl. From 500 to 1000 distributor rpm the advance goes from 1.5 to 7.5 degrees. From 1000 to 2000 it then goes to 10 degrees. I would like to see some specs for the late 70's to early 80's.
