Wheel bearings?
Old Feb 21, 2012 | 08:45 PM
zach7.3's Avatar
zach7.3
Wheel bearings?
So i took my truck to a shop to get some stuff done to it, because i didn't have the time. He fixed the wheel seals, front brake line, and fixed my oil leak. Now he said the ball bearings needed changed on all the tires. he priced the parts just at 600. So i am wondering what they really cost and how hard would they be for me to change them over the weekend? Thanks for all the help. Zach.
Old Feb 21, 2012 | 09:03 PM
ReBilld's Avatar
ReBilld
The rear end has floating axles and hub bearings, and unless you haul heavy loads alot, I doubt they are bad. Not saying they aren't, just doubt it. You can check them yourself by jacking each wheel off the ground and push in at the top of the tire while pulling out on the bottom. Try to move it up and down to see if ther is any play. You may have to pull the axles on the rear to get an accurate account of any play in the hub bearings.
The front wheel bearing aren't that hard to change, but yo will need a spindle nut socket (assuming your truck is 4x4) and a torque wrench. If you do change the front wheel bearings, make sure you change the spindle bearing too.
Old Feb 21, 2012 | 09:50 PM
oldbird1965's Avatar
oldbird1965
Listen to Bill Zach and find a new mechanic. He is trying to take you for a ride, hate that!!
Old Feb 22, 2012 | 12:03 AM
RubberDuck's Avatar
RubberDuck
Exactly, that dude is trying to rip you off. Do the test described with each wheel jacked up off the ground. If there is any up/down, play in the wheel you may need bearings. If not, you should be okay. On the fronts, give them a spin too. But yeah, I hate it when shops try to take advantage of you.
Old Feb 22, 2012 | 06:10 AM
zach7.3's Avatar
zach7.3
Is it the same for a dually, sorry i forgot to say that and its a 4x4.
Old Feb 22, 2012 | 06:15 AM
DIYMechanic's Avatar
DIYMechanic
This is a '94 F250 4x4 dually? Just making sure. B/C if the truck you're talking about is a Super Duty, that explains the higher prices. The SD front bearings cannot be replaced without replacing the whole hub assembly. It is a unit bearing.
Old Feb 22, 2012 | 06:17 AM
zach7.3's Avatar
zach7.3
Its only a f250 dually cause me and my brother changed the rear axle to a dually.
Old Feb 22, 2012 | 06:10 PM
ReBilld's Avatar
ReBilld
Did you do anything to the front?
Old Feb 22, 2012 | 06:34 PM
zach7.3's Avatar
zach7.3
Okay my bad we didn't change the axle we just put some spacers on and not sure about the front. I think we did change the axle because the tires were leaning in, but i'm not sure what we replaced it with it's been a while.
Old Feb 22, 2012 | 06:38 PM
ReBilld's Avatar
ReBilld
Does it have Budd wheels on the front?
Old Feb 22, 2012 | 06:49 PM
zach7.3's Avatar
zach7.3
Oh he was only talking about the back bearings that were bad, so I have no clue how he can get 600 out of that. That is a ridiculous amount of money for bearings. The reason he said they were bad was water got into them, is that caused from the wheel seals leaking? But I know I'm changing the bearings I know where i could put 600 into my truck else where like a new hpop or a new ts 6 position chip
Old Feb 22, 2012 | 07:00 PM
ReBilld's Avatar
ReBilld
If the rear hub bearings are bad I would change em.
1994 Ford Pickup F250 3/4 Ton - Rear Wheel Bearings and Seals Parts -TIMKEN,MOOG HUB ASSEMBLY,PARTS PLUS BEARINGS,ACDELCO PROFESSIONAL- Hubbearing.com
Old Feb 22, 2012 | 07:04 PM
zach7.3's Avatar
zach7.3
what kind would i need any idea? it's a f250 94
Old Feb 22, 2012 | 07:08 PM
ReBilld's Avatar
ReBilld
Check the link I left on my last reply. It will give you an idea of the prices.
Old Feb 22, 2012 | 07:17 PM
zach7.3's Avatar
zach7.3
yep i did thanks a lot. i'm going to try and get them done this weekend since i don't want anything else brake for not changing them.
BBslider001
Dec 29, 2015 06:50 AM
robs01f250
Feb 2, 2011 07:41 PM
Bronc1
1997 - 2003 F150
Aug 14, 2010 07:25 AM
fuelman
Aug 30, 2008 06:32 PM
david11690
Nov 24, 2006 07:14 PM
