2007 - 2014 Expedition & Navigator 2007, 2008, 2009, 2010, 2011, 2012, 2013 and 2014 Ford Expedition and Lincoln Navigator
Dang Deer...
Old 02-28-2012, 03:29 PM
ecyrbh's Avatar
ecyrbh
ecyrbh is offline
Dang Deer...
....So my wife is taking my oldest to school this morning in our 08 EB and a Deer decides to change ITS direction of travel and takes out the left front fender,left side mirror, and wheel opening trim....
My questions here are,..What has to be done to remove the left front inner door panel so that I can get to the mirror mounting bolts and is there aanything to be cautious of so that it doesn't break when pulling it apart???...
Insurance has already cut a check for nearly $2500.00 to repair it,but I need to get a mirror on it so that we can drive it safely until I can get it in the shop....
Old 02-28-2012, 05:01 PM
RI-Matt's Avatar
RI-Matt
RI-Matt is offline
Easy. 15 minutes tops.
Door Trim Removal:
1. Remove the door handle screw cover.
2. Remove the door handle screw.
3. Remove the door handle trim bezel.
4. Remove the front door trim panel finish cover.
5. Remove the 2 door trim panel armrest screws.
6. Remove the door trim panel screw.
7. Remove the 2 lower door trim panel screws.
8. Disengage the sail panel clip.
CAUTION: To avoid damage to the
door trim panel, lift the door trim panel by
pulling directly upward on the armrest to
disengage the panel clips.
9. Remove the front door trim panel.
10. Disconnect the electrical connectors.
11. Pull away the weather shield around the sail panel
12. Remove the 3 nuts, have someone hold the mirror from outside just in case.
13. Disconnect the electrical connectors and pull everything through opening.
Installation is reverse
PM me your email address if you need the diagrams of the parts referenced.
Matt
Old 02-29-2012, 10:59 AM
berry1234's Avatar
berry1234
berry1234 is offline
There is a push clip in the top corner of the sail panel. Careful here. Use your hands to pull the triangle portion of the door panel away from the metal door frame. If the clip won't come out slip a no-marring tool and pry the panel off. Then lift it up and over the black door lock ****. Then disconnect speaker wires and door lock/window switches.
Old 02-29-2012, 12:51 PM
ecyrbh's Avatar
ecyrbh
ecyrbh is offline
Thanks guys....all of the info helps a great deal.....This is a Great forum/website also...
wreakhavoc
12-01-2008 05:54 PM
shmoney1
1997-2006 Expedition & Navigator
07-25-2004 06:59 AM
vinman46
1997 - 2003 F150
06-24-2004 06:58 PM
Stylin
12-01-2003 02:11 PM
KDHammond58
1983 - 2012 Ranger & B-Series
03-23-2002 02:24 PM
Quick Reply: Dang Deer...
