clutch vibration
Old Feb 21, 2012 | 10:59 AM
gspot's Avatar
gspot
clutch vibration
i have a 58 panel with a 65 fairlane 289 motor and trying to put a t170ft trans from a 85 f150, my problem is that the bolt holes on the pressure plate are 3/8" and the bolt holes on flywheel are 5/16". i have tried using belliville washers or disc,cone washers but still have vibration when gassing motor, the more it revs yhe more vibration. the flywheel is sac#nfw1128 and cluth kit is sac#k0030-02. any help would be great since i have had this installed thee times.
Old Feb 21, 2012 | 11:35 AM
gfw1985's Avatar
gfw1985
Cranky Old Guy
I can not find the exact specs on your flywheel, but it appears you "may" have a imbalance problem. In 1982 Ford went from 28oz to 50oz imbalance on the 289/302/5.0 engine. You need to match flywheel to engine. I could easily be wrong, but appears to be the later model flywheel.
Old Feb 22, 2012 | 03:00 AM
stuart1's Avatar
stuart1
Drill and tap the bolt holes to 3/8".
Get proper bolts with shoulders.
mherlihy
Feb 7, 2016 07:53 PM
prafersno
Jun 10, 2009 08:59 PM
ranger74
Aug 10, 2005 09:29 PM
ozarkboy
Dec 2, 2004 06:21 AM
goodfoot
Aug 28, 2001 05:55 AM
