Rear wiper 2002 Ford Excursion
Old 02-21-2012, 07:38 AM
hawk1snest's Avatar
hawk1snest
hawk1snest is offline
My rear wiper was leaving big areas on the rear window when it would swipe over the glass. I though it was a bad wiper blade. Just bought a new one last night and it is still not working. It is leaving a large spot almost at the 12/1 oclock position on the window. Any ideas? The arm assembly is pretty tight, I can wiggle it a little. I took the black cap off wherre the arm attaches to the motor and the nut is tight.....
Old 02-21-2012, 08:01 AM
BuiltFordTough!'s Avatar
BuiltFordTough!
BuiltFordTough! is offline
The spring not strong enough? Or did the arm get bent slightly outward?
Old 02-21-2012, 08:28 AM
hawk1snest's Avatar
hawk1snest
Spring looked ok I think. Have not tried bending the arm yet did not think of that will try tonight--thanks!
Old 02-23-2012, 08:42 PM
nzirbel's Avatar
nzirbel
nzirbel is offline
I found out that my pivot on the arm was really stiff. I took the arm off and lubed the daylights out of it till it pivoted freely again. It's a heck of a lot better than it was, it just sort of sucks now rather than being completely worthless.
Old 02-24-2012, 04:39 AM
Shepherd2's Avatar
Shepherd2
Shepherd2 is offline
Mine does the same thing. Bent the arm every which way but it made no difference. I think it has more to do with using a straight blade on curved glass.
Old 02-24-2012, 05:30 AM
Curt's05's Avatar
Curt's05
Curt's05 is offline
Wiser by FTE
My solution was to remove the wiper arm & file/grind those 2 tabs. A new or stronger spring wont make any difference, because of the poor design.
Old 02-24-2012, 07:57 AM
GregN's Avatar
GregN
GregN is offline
Yeah, don't waste your money on buying a new arm either. I did that hoping to solve this problem, but it was exactly the same.
When I had a Jeep, I stumbled across an extra tensioning spring that you could add to the wiper, don't know if they would work or not:
Snuggies - Jeep Windshield Wiper Arm Tensioner
windshield wiper arm tensioner - Google Search
Old 02-24-2012, 02:10 PM
Sunline Fan's Avatar
Sunline Fan
Sunline Fan is offline
Excursion Fleet Manager
Mine doesn't seem to have a problem clearing water, but it does have a hard time successfully washing the whole window from salt spray. I get a spot in the center of the wiper path that doesn't really get cleaned.
unklscrufy
02-22-2020 05:37 PM
Michael Ward
1997 - 2003 F150
11-30-2018 12:56 PM
captcruz
08-18-2018 06:41 PM
03redstx
2011 to 2019 Explorer
05-31-2015 06:38 PM
gogriz2009
03-18-2010 01:27 PM
Quick Reply: Rear wiper 2002 Ford Excursion
