Sponsored by: Real Truck
Chrome Tow Hooks
Old Feb 21, 2012 | 12:13 AM
sprintnut's Avatar
sprintnut
Question Chrome Tow Hooks
Looking for a set of Chrome Tow Hooks for a 2000 F350.
Suggestions for the best source. Anyone ever price them new?
Thanks in advance for replys.
Sprintnut
Old Mar 3, 2012 | 11:05 AM
ccerniglia's Avatar
ccerniglia
Sprintnut
Ford Part#6C3Z 17N808-B Ford List..... are you sitting down? $200 each!
Old Mar 3, 2012 | 11:38 AM
Kajtek1's Avatar
Kajtek1
Chrome on tow hook? You know that chrome plating can not take loads on it?
Or you have garage queen and do it for looks only?
Old Mar 3, 2012 | 11:46 AM
ccerniglia's Avatar
ccerniglia
Regaurdless if they get used or not, the Chrome on those hooks hold up better then you think. I've pulled a few cars and a blazer out of the snow with them.
Old Mar 3, 2012 | 11:52 AM
powerstroker100's Avatar
powerstroker100
Lmao... garage queen... I like that
No way would I waste that kind of money for chrome tow hooks, if there starting to rust... pull em off and repaint them
Old Mar 3, 2012 | 02:08 PM
Sand_Man's Avatar
Sand_Man
You could take yours to a chrome shop. I'll bet it's a heck of a lot cheaper. As far as strength goes, I seriously doubt it would weaken it enough to even matter at all. Several years ago the term "Hydrogen Embrittlement" made the rounds in all the hot rod magazines and like all good myths, it got repeated enough to become fact. I've run hot rods and sand drag quads with chrome suspension, plus worked in a chrome shop and never, ever actually saw or heard of a chrome part failing due to it being chrome plated. Yet these stories pop up from time to time by people who don't know any better...
Old Mar 3, 2012 | 02:21 PM
PA-Mark's Avatar
PA-Mark
whoooooh there, slow down.... i think he ment the finish holding up.... atleast i hope he ment the finish, if not then yikes!
Old Mar 3, 2012 | 04:22 PM
Kajtek1's Avatar
Kajtek1
Excuse my 3rd language English, but I though that "chrome plating" is adequate description.
The plating can be done well, but the procedure is pretty long and usually involve copper plating under the chrome. Bottom line - it get screw up a lot and that is why you see so many bumpers, or bicycles with chrome peeling off.
No reputable car maker will put chrome wheels on the vehicles as that brings danger of loosing the air on flaking chrome.
Than chrome doesn't hold the paint well, so peeling off plating can be real pain to restore.
Old Mar 3, 2012 | 04:46 PM
onedcharette's Avatar
onedcharette
Just get them powder coated with the "chrome like" material. They have come a long way with powder coating to where it looks really fricken good. I bet for less than 75 bucks you can get them looking awesome. Just a thought.
Old Mar 3, 2012 | 05:16 PM
Sand_Man's Avatar
Sand_Man
Like I said, I worked in a plating shop, and the process is always the same, buff, copper plate. nickel plate. chrome plate, rinse. It's not a long process as you claim. The reason you might see plating flake off is that it wasn't prepped properly. This is typical of cheaper plating processes like the Chinese valve covers you buy for $20 at a swap meet. Nothing under the chrome but steel, and chances are it never saw a buffer at anytime during the plating process. How long would the paint last on your vehicle if they just shot it over the bare steel? Same thing. As for "no reputable car maker" using chrome wheels, I'm guessing you aren't aware of the huge aftermarket wheel industry. My chrome wheels on my F250 are doing just fine, even though I probably should wax them more than I do, but still no sign of peeling after several years of use. Also, chrome is quite easy to remove, and although it can be sand-blasted off, chrome shops can take if off chemically for very little money. I think chrome is just fine for what the OP's intended use is, and have often though of having mine chromed.
Old Mar 3, 2012 | 05:32 PM
Banage's Avatar
Banage
I would guess that if you use a strap, not a hook or chain the tow hook would not chip
Old Mar 3, 2012 | 05:47 PM
barthel's Avatar
barthel
I would not even consider having chrome tow hooks for as much as I use them. I'd wear them down to the metal in a few trips. Tow hooks are functional items, not "Bling".
Just 2 cents from an "Old Guy"
Old Mar 3, 2012 | 10:15 PM
powerstroker100
x2 I agree with you, my tow hooks have 3/8" rusted old chain rapped twice around them 24/7, constantly hooking up recovery chains/straps to it pulling out our race cars that sink in the yard
Old Mar 3, 2012 | 10:21 PM
MisterCMK's Avatar
MisterCMK
Tousley has them for $130 each.
Old Mar 7, 2013 | 02:40 PM
WickidPissa's Avatar
WickidPissa
Mine's a garage queen. I want them because they're bling.
Not afraid to admit that.
I have a 2004 though - I'm more than likely stuck with a plating shop, right?
Sand Man - how much would you charge out of your shop?
