Skipping second
Old Feb 20, 2012 | 08:27 PM
rangergirl94's Avatar
rangergirl94
Skipping second
I take my 93 f150 up to 20 mph let off and it skips to 3rd it has an e4od I changed the trans out of a truck that shifted great now it still the same the only thing I didnt change is the tq converter could a bad tq converter let skip a gear? If I pull it down to second it uses second but slips under power?
Old Feb 20, 2012 | 08:38 PM
Nick_lebbad's Avatar
Nick_lebbad
check your speed sensor? not entirely sure on this one but i think i had a friend with a jeep that did this and that was his problem i believe.. will call him tomorrow to verify
Old Feb 20, 2012 | 09:03 PM
White 97 xlt's Avatar
White 97 xlt
Pull the DTC codes.. Sounds like you have a code that was causing a problem before and still is...
The E4OD is COMPLETELY computer controlled, any trouble code can and most of the time cause the E4OD to go into limp mode, as it sounds like yours has..
Old Feb 20, 2012 | 09:20 PM
rangergirl94
Can I disconnect the batt termanal to clear the codes?
Old Feb 20, 2012 | 09:31 PM
Nick_lebbad
sometimes your computers don't just clear from disconnecting.. maybe try having your local parts shop clear your codes if you are able to safely drive it to one
Old Feb 20, 2012 | 09:33 PM
White 97 xlt
If you clear them they will just come back again.. You need to find the problem and fix it before you ruin this fresh E4OD..
Old Feb 20, 2012 | 09:38 PM
rangergirl94
With the new tranny when I put it in reverse it dies feels like its trying to take off in real tall gear?
Old Feb 20, 2012 | 10:17 PM
rangergirl94
I just tried to drive it after clearing the codes I lost all gears but 1rst
Old Feb 20, 2012 | 10:21 PM
blkF250HD's Avatar
blkF250HD
2nd gear is limp mode for most electronic transmissions. E4ODs also can have a problem with the filter coming loose and touching the bottom of the pan, causing a stall when engaging drive or reverse.
You could get lucky and have a sensor that went bad on you, or you could have burned up everything you just fixed by not following directions.
Old Feb 20, 2012 | 10:26 PM
White 97 xlt
Read post #3 and #6 again!!!!!
Old Feb 20, 2012 | 11:14 PM
rangergirl94
My tranny is not in limp mode!! It only has first gear limp mode is when its stuck in second ?
Old Feb 20, 2012 | 11:20 PM
DBGrif91's Avatar
DBGrif91
So when you swapped out the tranny is it possible that you didn't hook something up correctly?
I'm even more curious to know- what year/model truck did you get the other tranny from? It's possible a different year tranny out of a different model truck could be working improperly in your F150.
Old Feb 20, 2012 | 11:34 PM
rangergirl94
My truck is a 93 the truck I got the tranny out of was a 95 I drove the 95 it shifted very nice only had 111,000 so I pulled it and put it in my 93
Old Feb 20, 2012 | 11:55 PM
DBGrif91's Avatar
DBGrif91
Is your truck MAF [Mass Air Flow] or SD [Speed Density]?
I'm no expert but if your truck is MAF or SD, and the replacement tranny came out of a truck that was the other type, it's causing drivability issues.
It's also possible that if your truck is an OBD-I and the 95 is OBD-II that could be causing problems as well.
It's just a theory.
Old Feb 21, 2012 | 12:24 AM
rangergirl94
Both trucks are sd
