Help on Compression Check
Old Apr 24, 2003 | 10:51 AM
gdavis2265's Avatar
gdavis2265
I'm going to do a compression check, what is an acceptable PSI for the 300-6?
Also does anybody have the head torque specs and sequence they can send me. gdavis@rahco.com
Thanks guys
Old Apr 25, 2003 | 10:42 PM
steve83's Avatar
steve83
You're just asking for spam by posting your e-mail to a BBS. A moderator can edit it out for you.
The Haynes manual has the torque spec & pattern, and LOTS of other good info, so spend the $12.
For any engine, the lowest pressure should be at least 75% of the highest, and at least 85% of the adjacent cylinders. The actual pressure you get depends on the compression ratio, the ambient air pressure, the engine's condition, and the gauge's accuracy, so that's why it's rarely published. Ideally, it's 14.7 x the compression ratio.
