Catalytic Converters?
Old Apr 24, 2003 | 08:15 PM
teederj2002's Avatar
teederj2002
Question Catalytic Converters?
I am going to put a new exhaust on my '89 F150 and it has 2 catalytic converters on it. Can I just run one through it legally? And if so what type of highflow cat should I use?
Old Apr 25, 2003 | 10:01 AM
optikal illushun's Avatar
optikal illushun
check with the local emmisions laws for ur area. the truck will be fine if u removed one of the 2 cats. up here in we dont have to worry about emmisions so i hacked one off and the other one died on me so i have none.
Old Apr 25, 2003 | 11:30 AM
StrangeRanger's Avatar
StrangeRanger
Catco makes a high-flow 2 in/1 out converter that legally replaces the stock pair. summit sells them.
Old Apr 25, 2003 | 02:22 PM
optikal illushun
found it, part number CTO-9513. 2" in/single 2.5" out. 97.96 over at summit...
Old Apr 25, 2003 | 05:04 PM
teederj2002
Where can i find my local emmisions laws? I live in Missouri.
Old Apr 25, 2003 | 10:45 PM
bugeyed's Avatar
bugeyed
a dual in single out magnaflow cat will also pass emmisions test. If you need to know go to your local exhaust shop and they have a book that tells you what you can swap in.
