Not really of that much importance but i do need some help. Was wondering if any of you gents could possibly help me out. i need to test my injectors and the only peeps around here is a three hour drive to do so. So question is does any one have a pop tester that would be willing to test my injectors for me or maybe i could rent it from you.......... either way i need to get it done.
im in utah 30 mins east of dinasour colorado and 2 hours south of rock springs wyoming stuck in a ****ty little town called VERNAL! Why do you ask? ill be honest im just being cheap and dont wanna pay the diesel shop 41 bucks to equalize my injectors
i dont know how many miles are on them i really dont i just know they are a mixtre of the ones from my old 7.3 and this current motor thats in the truck and i dont believe that its my pump because my last pump was having issues and changed it to fix these issues and also because when i get into it it goes away just not when its idlein it blows a blueish grey color and its diesel cause it burns ur eyeballs
Vernal isn't that bad a town and I know there are shops there. $41 is cheap to match injectors. Even if you did have a pop tester, do you have shims?
you really should consider just replacing them.you shouldn't mix different codes,and the odds of them being any good is kinda slim.they're cheap compared to the fuel savings your going to get by just putting a fresh set in.
okay so as this may be it not being good thing to mix codes i got all the stuff to build my own tester and tested them all , with that aside i would like to know if there are any places that sell new ones for a good price at 50 bucks a peice and not knowin if there are all the propper codes not to mention im broke at the moment what codes were the best injectors and also would like to know how bad it is to run these things when they are or were firing at 500-1000 psi each. i shimmed them up and got them all to within 2-3 bar of each other firing at 1800-1950 psi any and all suggestions would be help full
