Driving on bad injectors
Old Apr 13, 2011 | 02:28 PM
f350rebel7788's Avatar
f350rebel7788
Disabled USMC Veteran
Exclamation Driving on bad injectors
Ok, so i have some bad injectors (one, two, three, i don't really know how many). i'm moving in a couple months from San Diego to Newbergh NY (about 3000 miles) and driving the truck the whole way. We have all kinds of things that we have to spend money on with the house we live in before we can move out, but i also know that i have bad injectors. If i can't get the injectors fixed before we move, how bad will it be to drive that far like it is?
Old Apr 13, 2011 | 04:06 PM
Copedawg's Avatar
Copedawg
IF your injectors are NOT firing then DO NOT drive it.
NOW, what makes you think your are not firing on all cylinders?
What are your symptoms?
Old Apr 13, 2011 | 09:56 PM
JamesHajek's Avatar
JamesHajek
How did you come to the conclusion that your injectors are bad?
Old Apr 13, 2011 | 11:20 PM
Brown Falcon's Avatar
Brown Falcon
Talk to Jim at Rosewood Diesel Shop. He's a great guy to work with, knows these injectors, and can probably help you out.
sales@rosewooddieselshop.com
Old Apr 13, 2011 | 11:40 PM
oldbird1965's Avatar
oldbird1965
I think if a few were not firing you would have a miss and white smoke, wag.
Old Apr 14, 2011 | 01:46 PM
f350rebel7788
YouTube - my slightly modded '94.5 7.3 powerstroke
i had everyone watch this video and even jim said it's missing... the only symptoms i've had is when i'm in a higher gear at lower speeds and hit the gas, anytime it's below 1500 rpm, it shakes like it's got parkinson's. it's been so rough it's made the dash trim fall off before, and my wife won't ride in it. i thought it was the fuel filter at first, changed it out, still same.
Old Apr 14, 2011 | 02:59 PM
oldbird1965
I didn't see any white smoke but it does sound like its missing. I thought about my white smoke theory, it doesn't apply. If a injector is not firing there is no fuel in the cylinder, duh.
Old Apr 14, 2011 | 03:04 PM
f350rebel7788
yeah, now that's it's been pointed out, it's really buggin me... haha so it's not a good idea to drive it that far like that???
Old Apr 14, 2011 | 03:09 PM
427 fordman's Avatar
427 fordman
Did you look at the vc harnesses? Did you isolate the problem?
Old Apr 14, 2011 | 04:22 PM
f350rebel7788
no, i haven't had the time lately... i'm hesitant to pull everything apart cause this will be my first time... but i guess it's gotta be done.
Old Apr 14, 2011 | 04:37 PM
427 fordman
It might be a vc harness. unplug one at a time and isolate it. Maybe you just need a harness, quick fix and you'd be good to go.
Old Apr 14, 2011 | 06:22 PM
Brown Falcon
Pulling the VC's isn't that bad. A couple bolts in the back are tricky to get to, but do-able with a u-joint and extensions.
Best way to check individual injectors is to pull the valve covers one at a time and then start the truck (don't worry it won't throw oil). Then unplug the electrical connector for each injector one at a time. If the idle doesn't change when that injector is unplugged it isn't firing. That's how Jim told me to check it when I was having problems and a bad miss.
Old Apr 14, 2011 | 06:23 PM
427 fordman
You can just pull the plugs on top first then you only may have to pull one vc..
Old Apr 14, 2011 | 06:28 PM
Brown Falcon
That will work but not as acurate and harder to tell if thats the problem one because you are disconnecting 2 at a time that way.
Old Apr 14, 2011 | 07:03 PM
427 fordman
Ya, but you'll still be able to tell by it hitting on 6 instead of 7. I do agree it would be best to pull both vc's, but if he's in a hurry, and money is tight, you should be able to tell the sound difference and get to it.
