2.8 fuel injection
Old Apr 24, 2003 | 10:11 AM
camokids's Avatar
camokids
2.8 fuel injection
anyone swaped a f/i system on to an 85 BII, or have any knowledge on where to start?
Old Apr 24, 2003 | 07:22 PM
Ford_Six's Avatar
Ford_Six
2.8 fuel injection
Welcome to FTE-
I think the best place to start would be to look into a TBI system, unless you want to go with a multi-port system like the 2.9. If you were to take a TBI system off of a chebbie 2.8, like a mid- to late-80's S-10, that would work. You would have to wire it up, and probably punch a hole in the firewall for the harness, and adapt the throttle body to your intake, but that system will run that motor.
Old Apr 27, 2003 | 10:51 AM
camokids's Avatar
camokids
2.8 fuel injection
well i found a donor 86 BII. i'm gonna swap everything that's related to the f/i (intake,'puter ,wiring,etc.)onto my 85 BII.
any thoughts anyone?
Old May 5, 2003 | 08:43 AM
thelonerangerxlt's Avatar
thelonerangerxlt
2.8 fuel injection
Camo, you'll also need the in-tank fuel pump, and related wiring to operate it. If you are just trying to get rid of the feed-back carb system that you now have, it's a lot of trouble.
On an 84 BII that I previously owned, I swapped the feed-back carb for an older model Motorcraft 2150 (re-jetted with #53s). I then pulled the EEC distributor, related wiring, vacuum solenoids, and computer. I replaced the entire mess with a Mallory Unilite aftermarket distributor. After re-timing and tuning the carb, the BII ran like a champ.
Old May 9, 2003 | 08:19 PM
camokids's Avatar
camokids
2.8 fuel injection
sounds like you did the duraspark conversion
but i live in the smog buster capital of California and that would never pass inspection
so my plan is to switch EVERYTHING and i mean all of it
and hope it flies at the referee station (that's where modified,with improvements,vehicles go to be approved for smog)
