I don't think so Mike, but I'm not sure either. Used to know, can't remember (crs). I ordered a new one and a new clamp for an early 99 when I did mine...
I got it figured out the V in the clamp was spread out and not pulling the spyder and turbo together so I bent them back together with a pair a channel locks
Did you use the same v clamp? because till I know the o-ring its the same but not the clamp (little wider), but I have read that you can use the stock clamp IDK, when I installed mine change the clamp and a new (same #part as the stock) o-ring.
