Coolant Leak - Source?
Old Feb 19, 2012 | 05:57 PM
IHbase's Avatar
IHbase
Passenger exhaust manifold is moist on the bottom with two large drops of coolant. What do you guys think the source could be?
Thanks in advance.
-Mike
Old Feb 19, 2012 | 06:04 PM
npccpartsman's Avatar
npccpartsman
Oil cooler to EGR cooler hose underneath the blue, elbow, turbo hose on passenger side.
Old Feb 19, 2012 | 06:23 PM
dee004's Avatar
dee004
As above. If you get under thr truck with a flashlight and look up towards the rear of the engine under the turbo you'll probably be able to see the path from the top of the engine around the head down to the exhaust manifold.
Old Feb 19, 2012 | 06:47 PM
Ben FORD's Avatar
Ben FORD
Check the heater return hose that runs from the heater back across the firewall............
Old Feb 19, 2012 | 10:16 PM
mschultz's Avatar
mschultz
Thanks for the replies. I see the EGR cooler line, but it looks like a bitch to service. I'll check the heater lines in the morning. Should I attempt to tighten (re-clamp) the EGR hose or should it just be replaced?
-Mike
Old Feb 19, 2012 | 10:20 PM
dlibson's Avatar
dlibson
Seen the heater valves leak too...
Old Feb 19, 2012 | 10:24 PM
amdriven2liv's Avatar
amdriven2liv
I'm hitting easy street
-Mike
What color is that EGR hose? You didn't mention your model year, or I missed it. Just went and see you have an 06, so it should be blue.
If it is a stock hose on the EGR, they don't have clamps. And they are not too difficult to replace. There are a couple threads on this topic.
They can leak, but the older years had an orange one that failed a lot.
As posted above, check the heater control valve on fire wall passenger side.
hasteranger
Nov 17, 2016 08:58 PM
yidakimason
Apr 2, 2015 10:54 PM
olbattlebuggy
Feb 14, 2011 02:02 AM
04scurs
Dec 10, 2009 11:04 PM
neverman
Jan 18, 2007 02:26 AM
