gas saving products
Old Feb 20, 2012 | 07:14 PM
tjc transport's Avatar
tjc transport
i ain't rite
that is why we moderators are but humble servants to the masses here at FTE.
we will do almost anything to help keep monitor screens cleaned on a regular basis.
Old Feb 20, 2012 | 08:04 PM
khakushia's Avatar
khakushia
i just installed a set of E3 spark plugs with some msd ignition wires on my suburban that lets me know my mpg. i will fill you in if there any improvement
Old Feb 20, 2012 | 08:45 PM
Midnite1987's Avatar
Midnite1987
These trucks in better on the plain old copper sparkplugs. The only effect the E3 plugs will have is on your wallett
Old Feb 20, 2012 | 09:01 PM
Beechkid's Avatar
Beechkid
Originally Posted by ItsAFord55
Just out of curiosity does this crap work? Tornado Air Tornado Performance Booster - JCWhitney
Carburator yes 9very slightly) because it helps create increased turbulance in the intakes where the fuel/air mix....EFI, no, because it is injected directly into the cylinders.
Old Feb 20, 2012 | 09:58 PM
the57man's Avatar
the57man
made me laugh!!!
Originally Posted by tjc transport
yall don't know what yall are talkin bout!
i put 3 tornadoes and 2 airad throttle body spacers in my intake hose, and then put 4 set of magnets to align the fuel molecules in the fuel lines on my truck.
then i built a water to gas hydrogen generator, and installed a platinum converter that takes the platinum out of the catalytic converter and makes platinum gas to supplement the hydrogen the WTG makes and combines to two gases for injection directly into the combustion chamber.
my truck is so efficient now it actually fills the gas tank as i drive.
every night i have to siphon 10 gallons out of the tank and pour it into neighbors cars, otherwise the tank overfills and spills gas out onto he road as i drive.
now that was funny!!!
Old Feb 21, 2012 | 07:09 AM
tjc transport
i ain't rite
incorrect.
the butterfly plates in the carburetor eliminate any of the "turbulence" the manufacturer claimes it makes.
Old Feb 21, 2012 | 07:21 AM
jroehl's Avatar
jroehl
Also incorrect because the EFI injects fuel into the lower intake manifold, which, in airflow terms, is before the cylinder heads, which contain the intake valves that allow the fuel-air mixture into the cylinders.
There are vehicles out there with direct injection--modern diesels, and a few European gas cars also, but our Fords are not among them.
Jason
Old Feb 21, 2012 | 10:19 AM
88dually's Avatar
88dually
How a bout a flux capacitor ?
Old Feb 21, 2012 | 11:55 AM
Scooter70's Avatar
Scooter70
Bought 2 Flux capacitors today. Mounting 1 on each tube on my 460.Hoping to achieve 88mpg since I can already do 88 mph.
Old Feb 21, 2012 | 12:55 PM
White 97 xlt's Avatar
White 97 xlt
Naw!!! Just loosen the muffler bearing two turns........................
Old Feb 21, 2012 | 01:36 PM
tjc transport
i ain't rite
clockwise, or counterclockwise?
i always get those two cornfused as to which way turns up fuel and which way turns it down.
Old Feb 21, 2012 | 01:47 PM
Freightrain's Avatar
Freightrain
Inspect them on a regular basis. If they become stiff from lack of grease, your mileage will suffer.
Here's mine:
Still looks good, even though the muffler is almost gone. I'll likely just reinstall them in a new muffler casing.
BTW,
Righty= Tighty=More power
Lefty= Loosey=better mileage
Years back a buddy did a plug test on his Turbo Coupe(at the dragstrip). New motorcrafts, autolites and Splitfires. No difference at all(go figure). The only reason anyone gets better power from a set of fancy plugs is the fact their old plugs were so toast ANY new plug would make it run better.
Old Feb 21, 2012 | 01:53 PM
  #28
Beechkid's Avatar
Beechkid
Jason
I stand corrected (GRIN)!
Old Feb 21, 2012 | 01:57 PM
  #29
Beechkid's Avatar
Beechkid
Jason
Correct- the injectors are so close to the cylinder, a Twirl device has little to no effect as compared to a carburator...that has long runners and give the fuel/air time to increase turbulance and mix.
Old Feb 21, 2012 | 02:22 PM
  #30
Skip1970's Avatar
Skip1970
date skinny girls, thats helps allot. get a shamoo in there and shell make your mpg go way down.
