VSS Leak
Old Feb 19, 2012 | 02:12 PM
EX40's Avatar
EX40
VSS Leak
I've had an ABS light on for awhile now & appears to be from the VSS. When I looked this is what I found.
Anyone experience this before. It's been replaced before by a mechanic. Wondering if it's some o-ring failure. I couldn't get the bolt loosened at the time but plan on tackling it next weekend.
Old Feb 19, 2012 | 02:14 PM
EX40's Avatar
EX40
Here's another angle.
Old Feb 19, 2012 | 02:33 PM
wpnaes's Avatar
wpnaes
Yes, I've done this R&R last year. Super easy and an inexpensive part. That sensor is also a magnet, probably a good idea to clean it off every decade...
Old Feb 19, 2012 | 02:34 PM
wpnaes's Avatar
wpnaes
Looks like your o-ring is leaking. A new one comes with a new o-ring which should help.
Old Feb 19, 2012 | 03:56 PM
TrdLtly's Avatar
TrdLtly
TreadLightly
Just replaced mine on Friday. $16 at O'Rielly. Less then 5 min to replace. Took care of my ABS light. The parts guy said that it is very common replacement part on Ford's and Dodge's. Put a little grease on the o'ring before you insert it.
Old Feb 19, 2012 | 06:09 PM
EX40's Avatar
EX40
I've never seen one leaking. That was my concern. Was it something bigger that a bad o-ring. We'll find out next weekend.
ExPACamper
52
Jun 3, 2017 05:55 PM
JL-KA
Nov 9, 2016 12:45 PM
Jaime74656
15
Jul 28, 2015 11:17 AM
Freakmonger
17
Feb 27, 2014 01:27 PM
JonathanN
Dec 5, 2012 03:37 PM
