max boost banks sidewinder?
Old Feb 19, 2012 | 03:19 AM
IDI guy's Avatar
IDI guy
If you studded your head and had a high output IP had pistons cut 19-1 compression ratio what could a banks sidewinder put out for boost. Just curious, some one has to have pushed one before.
Old Feb 19, 2012 | 03:40 AM
91dirtydiesel's Avatar
91dirtydiesel
You looking to be efficient or just see a big number? Can u find any maps for the Mitsubishi TEO6H? That would tell you it's capabilities
Old Feb 19, 2012 | 03:48 AM
IDI guy's Avatar
IDI guy
I was just wondering. I was thinking about making an ARP order and studding my head on my 88. I was wondering if it would be worth it to stud the 90 too don't want to get a diffrent turbo but I want to push more boost if the sidewinder can't push more than 12 psi efficently I won't do it.
Old Feb 19, 2012 | 08:35 AM
tjc transport's Avatar
tjc transport
i ain't rite
my non wastgated banks unit will throw 16 lbs boost at full throttle pulling a load without a muffler.
ran it that way for 16 years.
Old Feb 19, 2012 | 05:09 PM
Aune163rd's Avatar
Aune163rd
are you studding your heads TJC???
Old Feb 19, 2012 | 06:23 PM
tjc transport
i ain't rite
why bother?? it has 493,000+ miles on it and still runs like new.
when it gets a bit warmer i am swapping the cab and will put valve cover gaskets in the engine to slow down the oil leaks, but that is as far as i am going with it.
Old Feb 19, 2012 | 07:42 PM
NMB2's Avatar
NMB2
Something that has been overlooked for a long time until mine and Racin's builds are the camshafts.
The camshaft I came up with helps gets rid of a lot of the issues associated with blowing HG's on these engines.
As for boost, 15psi is really the efficient limits of the stock chargers compressor sides.
Old Feb 19, 2012 | 08:40 PM
IDI guy's Avatar
IDI guy
What is involved in grinding the cam besides the obvious taking the cam in to get it ground, IE; pistons, rings, berrings, valves, lifters, what needs to be changed when doing the job. What does the grind do to the timing of the valves to make it less prone to head gasket failure? How would a guy go about getting the design of the cam you came up with? I have this much power(---------) and I want this much (-------------) maybe this much(----------------) but I'm not sure im ready for all that power though.
Old Feb 19, 2012 | 08:49 PM
NMB2's Avatar
NMB2
I'll PM you some info on the swap.
Old Feb 20, 2012 | 10:33 AM
Festus Hagen's Avatar
Festus Hagen
Methanoholic
Whats Delta's number on that Cam ??
-Enjoy
fh : )_~
Old Feb 20, 2012 | 12:22 PM
NMB2's Avatar
NMB2
-Enjoy
fh : )_~
no number. its "my" cam, and they aren't openly dealing them.
If you, or anyone else is interested in obtaining one, just let me know and I can help you out.
Old Feb 20, 2012 | 01:59 PM
Aune163rd's Avatar
Aune163rd
NMB2 send me a PM...i got two engines with cams in them...I talked to typefour. Is yours the same?
Old Feb 20, 2012 | 02:01 PM
NMB2's Avatar
NMB2
No, they are completely different animals. Russ's is an RV style cam, this is a turbo cam.
EDIT: Tried checking PM's but it appears I don't even have a PM box.
I don't even see where to turn it on, can somebody help me out?
Old Feb 20, 2012 | 02:04 PM
Aune163rd's Avatar
Aune163rd
So yours is made for higher end speed??? And Russ's is made for pulling? Next question....can you post a picture of your GP bracked you fabbed onto your truck...i just turbo'd my 84's motor and put it into the truck, now i need to get the GP's and whatnot working in the cab....what did you do?
Old Feb 20, 2012 | 02:06 PM
NMB2's Avatar
NMB2
No, its not that clear cut.
if I can get these PM's to work I'd be happy to explain it to you.
